Price for wheels is 2150EUR + Shipping for one set! Shipping possible in EU and Worldwide! Extra strong boxes for shipping available too!
Wheels fit to A5,S5,RS4, RS5, RS6 C5, RS6 C6.
Pictures:
INFO: PM or litledevil@gmail.com
I would reckon at least 5mm which would take it to ET28 (OEM ET29). So if you are running 8mm on front and 10mm on rear on OEM wheels it will likely be 12mm front and 15mm rear.klauster wrote:would these fit an RS4 B7? the offset is different, would you need to fit spacers?
Is that right? Thought the lower the et the further they stick out?P_G wrote:I would reckon at least 5mm which would take it to ET28 (OEM ET29). So if you are running 8mm on front and 10mm on rear on OEM wheels it will likely be 12mm front and 15mm rear.klauster wrote:would these fit an RS4 B7? the offset is different, would you need to fit spacers?
Found it.klauster wrote:would these fit an RS4 B7? the offset is different, would you need to fit spacers?
Users browsing this forum: Google [Bot], JonesyJ and 72 guests
