Cold air feed inlet added
PetrolDave
Re: Cold air feed inlet added
Post by PetrolDave » Thu Feb 09, 2012 9:31 am
DavidRS4 wrote:Possibly a stupid question, but how do the fog light grills come out as I would like to clean mine to. Do they simply pull out? Obviously I don't want to break them.
Yes, they simply pull out - just take it easy and you'll see where the retaining tabs are so you can flex that area more and they'll come out real easy.
adsgreen
Post by adsgreen » Thu Feb 09, 2012 10:19 am
yup - watch your knuckles though. just give em a pull.
P_G
Post by P_G » Thu Feb 09, 2012 10:48 am
God work there sonny, definietly gives it a more purposeful finish rather than a DIY instal. The gauze is a good idea too, I doubt you'll notice the difference between having it there and not performancce wise but maybe good to curtail stray debris getting in there.
adsgreen
Post by adsgreen » Thu Feb 09, 2012 10:59 am
P_G wrote:God work there sonny, definietly gives it a more purposeful finish rather than a DIY instal. The gauze is a good idea too, I doubt you'll notice the differecne between having it there and not performancce wise but maybe good to curtail stray debris getting in there.
Bah - thats what the air filter is for ;)
P_G
Post by P_G » Thu Feb 09, 2012 11:06 am
True but better that mulch gets stopped there and the air filter still has optimum performance for air flow from main / other source than mulch inhibiting the performance of the air filter. :bigblink:
sonny
Post by sonny » Thu Feb 09, 2012 11:34 am
as Dave says, the three tabs are located at the top of the grill, pull these down and the grill will slide out, inner side first then outer part next to fog light will slide out.
sonny
Post by sonny » Thu Feb 09, 2012 12:53 pm
j1sgo wrote:Nice, does that then fit into the airbox hole where you removed the flap, how did you secure it as if i remember there is a trumpet on the airbox isnt there?
Yep there is. The airbox snorkel comes off, this houses the flap and vacuum actuator.
I split mine, and fixed the the bottom half back on. So at a later stage I could put it back together if I want.
Only modification I made was to a large plastic tab that stuck out (in red circle), I simply cut 4mm off the end, so the 89mm tubing slides over and fastened with a jubilee clip, this also acts as a lip to keep the ducting in place.
If you are still running with the IM flaps or IM vacuum system then you will need to trick the car in thinking the air box flap is still there. MRC fitted a resister/bypass switch (cant remember what it was, will get back to you as soon as I remember/find out).
Dont have any pics of the ducting connected to the air box, but there's a few pics kicking around on this site.
Tabs removed here to split snorkel
Plastic tab, shaved 4mm off.
Airbox, you can see the side wing vent.
sonny
Post by sonny » Thu Feb 09, 2012 12:57 pm
P_G wrote:God work there sonny, definietly gives it a more purposeful finish rather than a DIY instal. The gauze is a good idea too, I doubt you'll notice the difference between having it there and not performancce wise but maybe good to curtail stray debris getting in there.
Thanks Graeme, yes I like the look of it, I purchased the mesh as I remember reading somewhere that mice/rats had made a nest in an owners car airbox (cant remember what forum it was) I know these are popular in the states, also it does help preserve the life of the air filter. Since having the CAF I was amazed as to how much crap was in the air box.
Only does side I am guessing will be stone chips, but at a tenner its a cheap replacement.
DavidRS4
Post by DavidRS4 » Thu Feb 09, 2012 9:47 pm
Thanks guys for the explanation on how to take out the grills, don't want to break them. Thanks for the tips :thumbs:
j1sgo
Post by j1sgo » Fri Feb 10, 2012 8:51 am
Nice work, and cheers for the post, i know whats involved now when the drivers aux rad packs in :)
Post by Shoppinit » Wed Feb 15, 2012 12:27 pm
Does the aux rad absolutely have to be deleted for this mod?
lengster1
Post by lengster1 » Wed Feb 15, 2012 12:52 pm
Yes
j1sgo
Post by j1sgo » Thu Jul 26, 2012 10:07 pm
As the car is off the road waiting for a drc repair i thought i would Take the bumper off after work tonight, ready to do this mod Saturday :bigblink:
Sonny/all, a quick few questions if you didn't mind before I start:
1. I notice the aux rad ducting is actually fixed to the aux rad, obviously this is being removed, how did you re-fit the ducting after? Zip ties, brackets or something?
2. I assume if I just block the vacuum pipe to the airbox flap, this will be job done?
3. I couldn't see the radiator drain plug after a quick look, normally a plastic red plug isn't it? Anyone know where?
3. My light washer jets don't seem to work, firstly I assume they should just work when the lights and ignition are on? Secondly they look like they just pop out/work on water pressure so I think the pump must be f####d?
P.s I know what to do with the water pipes thanks to mrc :beerchug:
adsgreen
Post by adsgreen » Thu Jul 26, 2012 10:22 pm
2. Yep - just block the vac pipe.
sar
Post by sar » Thu Jul 26, 2012 11:36 pm
im thinking of having a go at this myself so if i can add a couple of questions,
is 89mm pipe the largest diameter that will comfortably fit?, i dont mind modifying the airbox a little bit if needs be.
also what connectors would i need for the water pipes when i delete the radiator?.
Users browsing this forum: No registered users and 171 guests
