Fuel pump noise?
Fuel pump noise?
UK car FASH 76k new to me as of yesterday(from S2 so familiar with basics)
Transient noise from fuel pump on start up Views welcome
A whining noise is probably either the pump giving up or a clogged filter causing it to work harder. I am surprised that yours is making a noise at only 76k. Mine gives an occasional whine now and again but its done 145k+ and I recently replaced my filter which cured some dangerous lean running too. If you are going for bigger power you can replace the sock pump with a Bosch Motorsport item which is good for well over 500horses on the I5. Since the motorsport pump is larger than the existing in-tank unit, you need a few additional parts in order to fit it. Total cost for the Bosch pump and associated bits is around 200quid.
Lee
Lee
1995 S2 Avant with a few mods
"Rattle" on start-up?
Is the noise a bit of a sort of "rattle"-like noise? Mine's been doing that for 2 years now and occasionally whines a bit, too. Changed filter to no avail. Am told it's slowly on the way out, at 115k miles, but then it's been doing it for 2 years now and still goes just fine....
01 Goodwood Green RS4. Stage II MRC (460BHP/480lbft).
Audi S8 5.2 V10 Daytona Grey, RS4-type alloys, B&O sound [Gone]
95 Ragussa Green RS2, unmodified and great [Gone]
You need to drop the tank to change the filter on the 80Avant Quattro chasis. It's a PITA. I cut the plastic bracket (which is welded to the plastic tank) and fitted a larger S2 ABY Coupe filter to mine. Apart from some petrol in my eye, I did the job in about 30minutes.
i have the same noise, i think !
turn the key, after start up the car idles, then i begin to hear what i think is the pump going flat out, then the noise disapears
seems like its getting up to pressure then levelling out
mine has been like this for years ! never caused a prob
Davidp20v
Rs2. Polar Silver. Was Standard 315 bhp. now with de-cats, cone filter, forge diverter valve. samcos next, then chip
i purchased a fuel filter with the intention of changing, but after hearing they are a right pig on the avants over on s2 forum,
i have decided to delay the job .....
....for about 8 months now !
Davidp20v
