Dectane LED Tail Lights Errors??
andre3k
Post by andre3k » Wed Jan 25, 2012 1:39 pm
Is anyone running the Dectane RA16SLRCL tail lights or equivalent in smoke on an avant?? (Not the litec ones)
https://www.dectane.de/index.php?cat=c9 ... tml&page=2
The car's getting detailed atm and I left them the lights to fit and they've come back telling me it's throwing an error; specifically the indicators. Any ideas?
Cheers folks
MB2
Re: Dectane LED Tail Lights Errors??
Post by MB2 » Wed Jan 25, 2012 1:50 pm
I don't have these lights, but my guess would be the indicators are LEDs & so triggering a "bulb out" warning, if so a couple of these resistors wired into the lights should sort you out (one for each indictator).
http://forum.rs246.com/viewtopic.php?f=35&t=94575
klauster
Post by klauster » Wed Jan 25, 2012 1:59 pm
I only get an error if I leave auto lights on, other than that they work perfectly without errors
Post by HYFR » Wed Jan 25, 2012 2:01 pm
they should be plug and plug
no errors
the only error i had on mine was with autolights, where if you turned the iginition on when it was dark, the autolights was turnon before the car had a chance to figure out the lights turned on and so threw a bulb out warning ... simply switching the lights off and on solved it.
andre3k
Post by andre3k » Wed Jan 25, 2012 2:04 pm
MB2 wrote:I don't have these lights, but my guess would be the indicators are LEDs & so triggering a "bulb out" warning, if so a couple of these resistors wired into the lights should sort you out (one for each indictator).
Thanks for that. If it comes to it & I can't resolve it I might PM you for more info as I'm totally inept when it comes to that sort of thing :thumbs:
andre3k
Post by andre3k » Wed Jan 25, 2012 2:05 pm
Klauster & DK were your indicators LED?
DazN
Post by DazN » Wed Jan 25, 2012 2:22 pm
Mine give an error every single time I start the car with the lights switched to anything but off. If I get the error and switch off and on again the error goes.
I spoke to Dectane and they said it's because the lights are designed for LHD cars and the resistors are wired specifically for that, I considered running the wires from left to right and vice versa in the boot but didn't bother.
Audi S4 (B9)
Gone:
C63 Coupe (2014)
Audi S4 (B8)
BMW M3 (E90)
Audi RS4 (B7)
BMW M5 (E60)
BMW M3 (E46)
Post by HYFR » Wed Jan 25, 2012 2:27 pm
yes mine were led indicators
P_G
Post by P_G » Wed Jan 25, 2012 5:31 pm
I run RA16LR's and as said if you have the switch to 'auto' and it is dark enough for auto lights to trigger on start up they will throw a bulb out warning, mine is for fogs. Either start the car in the dark with lights off or quick 1 second flick of switch from auto to off and back again clears it.
It also only happens if the car is sat for more then 5 hours for some reason. If less than that from the last time they were on it works fine. I gather this must be the time the resistors lose their impedence.
edge
Post by edge » Thu Jan 26, 2012 9:52 am
DazN wrote:Mine give an error every single time I start the car with the lights switched to anything but off. If I get the error and switch off and on again the error goes.
I get the same every so often, just swtich them on and off and no issues.
I think its worth the pain as they look cool ;)
Jonesy07
Post by Jonesy07 » Thu Jan 26, 2012 10:58 am
Mines the same :bash:
Current : S3 8p while on the RS3 hunt.
Previuos : B7 RS4 Avus Avant | RS4 Sal | R32 | Cayenne | Z4M | R32
Shadow6ix
Post by Shadow6ix » Thu Jan 26, 2012 11:52 am
andre3000 wrote:Is anyone running the Dectane RA16SLRCL tail lights or equivalent in smoke on an avant?? (Not the litec ones)
Cheers folks
Pictures of them on your avant would be appreciated if you get the chance :)
edge
Post by edge » Thu Jan 26, 2012 5:33 pm
Heres them on a less ghetto booty model!
Shadow6ix
Post by Shadow6ix » Fri Jan 27, 2012 12:16 pm
lol... thankyou! I can't make my mind up about these things. I think I'd probably want clear instead of smoke.
edge
Post by edge » Fri Jan 27, 2012 12:24 pm
Shadow6ix wrote:lol... thankyou! I can't make my mind up about these things. I think I'd probably want clear instead of smoke.
I think the clear look very 'Lexus' and thats whats spawned every boy racer/modder buying them for there cars, but to each there own ;)
Users browsing this forum: 666Lenine, Bing [Bot], Google [Bot], Google Adsense [Bot], Zyox and 195 guests
