Ceramic Brakes
- Dave_Hedgehog
- 5th Gear
Ceramic Brakes
can you just change the discs on the RS3 for ceramic ones or is it more complicated than that?
The Hedgehog, creator of RS4.org, back in of the RS fold yet again, third time lucky
Ceramic Brakes
Im guessing you will need new callipers, bells and also needs the ecu re-coding for wet weather driving .
- Dave_Hedgehog
- 5th Gear
Re: Ceramic Brakes
Re: Ceramic Brakes
that just shows wow a ceramic disk is made, the main thing will be the seals in the pistons on the caliper, and as Sonny says the ecu coding so it doesnt keep kicking the ABS in, can you get ceramics for the RS3?
what are you running at the minute and what is the reason you want ceramics, some people on here just want the mods for pub talk and dont actually need them. ( not implying this is you btw)
- Dave_Hedgehog
- 5th Gear
Re: Ceramic Brakes
never really looked at them before
was just wondering if it was a straight disc swap which it appears its not
i tend to be a bit heavy on discs ...
Re: Ceramic Brakes
I've fitted a set on my b5 rs4 , fantastic ......
Unit 20
0151 3366888
0151 3366888
- Dave_Hedgehog
- 5th Gear
Re: Ceramic Brakes
linky?grizz wrote:I've fitted a set on my b5 rs4 , fantastic ......
cost?
difficult to do?
Re: Ceramic Brakes
Got one photo of them fitted , Took a bit of work to fit as the offset was different .
I paid £3500 for the full set up .
They just fit under the 18's as well ..
Unit 20
0151 3366888
0151 3366888
- Dave_Hedgehog
- 5th Gear
Re: Ceramic Brakes
v nicegrizz wrote:Got one photo of them fitted , Took a bit of work to fit as the offset was different .
Re: Ceramic Brakes
Before fitting.
Unit 20
0151 3366888
0151 3366888
Re: Ceramic Brakes
Grizz how much would these cost to fit on my C5?
Would the ABS need some sort of adjusting or not?
C7 A6 allroad 3.0TDi.
Tiguan 2.0TDi R-line
- geek
- Location: I was there for a while but now I am here, definitely here.
Ceramic Brakes
This is resurrecting an old thread but it is the closest result I could find to my question.
Can you buy a COTS OEM upgrade to Ceramics (full set up) for the 3?
Re: Ceramic Brakes
Seen a set on a tt-rs so assume its possible. not sure how easily though...
Users browsing this forum: Majestic-12 [Bot] and 145 guests
