Avant rear wiper
yorkie
Avant rear wiper
Post by yorkie » Wed Dec 28, 2011 10:28 am
Anyone replaced their rear wiper blade - is it a faf?
mikeypur
Re: Avant rear wiper
Post by mikeypur » Thu Dec 29, 2011 11:00 am
I replaced the whole wiper arm with one off a '09 Q5.. Looks and functions much better
B7 RS4 Daytona Grey Avant
yorkie
Post by yorkie » Thu Dec 29, 2011 11:08 am
Cheers for the reply, how easy is it to remove the old one?
On my S4 it had welded itself to the spigot and never managed to remove it.
mikeypur
Post by mikeypur » Thu Dec 29, 2011 6:34 pm
Mine was a bit of a pain in the ass to remove but I just persisted with it and it eventually loosened and came off!
Timster
Post by Timster » Thu Dec 29, 2011 7:36 pm
yorkie wrote:Anyone replaced their rear wiper blade - is it a faf?
It's a piece of p"*ss to change.... takes seconds with the OEM blade.
Dont know what all the fuss is about.
yorkie
Post by yorkie » Thu Dec 29, 2011 10:05 pm
Maybe a piece of p**s if you know how but I dont so that was why I am asking.
Constructive replies welcome.
johnnydog
Post by johnnydog » Fri Dec 30, 2011 1:48 am
The blade is covered by a plastic shroud. You simply lift the arm from the glass, and pull the metal blade away from the shroud. I would suggest using two fingers either side of the cente of the blade, and a sharp pull will dislodge the centre pin on the blade from the shroud. The replacement blade then simply clicks back in place of the old one - just ensure the blade is the correct way as from memory the mounting is not exactly in the centre. It really is very easy - hope that helps!
yorkie
Post by yorkie » Fri Dec 30, 2011 10:07 am
Thanks that helps a lot!
I had sort of guessed that was what you did but knowing me (bull in a china Shop) I would have missed some small detail and broken it.
yorkie
Post by yorkie » Sat Dec 31, 2011 11:57 am
Cheers, was very easy even for me!
Only £8.64 all in from Audi too.
johnnydog
Post by johnnydog » Sat Dec 31, 2011 6:52 pm
Glad you sorted it!
Users browsing this forum: No registered users and 587 guests
