01543 parking aid warning chime fault
Rick_RS4
Post by Rick_RS4 » Wed Dec 28, 2011 4:41 pm
when i put the car in reverse i get a long beep from the front (dash) of the car and the P light flashes constantly
did a scan and i get
01543 parking aid warning chime (h15) 31-00 open or short to ground
google is scetchy one thread says its the beeper in the parcel shelf of the boot?
any ideas?
PetrolDave
Re: 01543 parking aid warning chime fault
Post by PetrolDave » Wed Dec 28, 2011 5:12 pm
Rick_RS4 wrote:when i put the car in reverse i get a long beep from the front (dash) of the car and the P light flashes constantly
any ideas?
Google is right - there's a beeper under the parcel shelf that normally sounds when you're reversing and get close to an object. That beeper (or the wiring to it) is faulty.
Carried any large loads recently in the boot that may have disturbed the wiring?
klauster
Post by klauster » Wed Dec 28, 2011 5:40 pm
I have the same issue, seems to come and go though :/ will get it checked out next time I'm at Audi
Rick_RS4
Post by Rick_RS4 » Wed Dec 28, 2011 7:08 pm
PetrolDave wrote: Google is right - there's a beeper under the parcel shelf that normally sounds when you're reversing and get close to an object. That beeper (or the wiring to it) is faulty.
no, boot is always empty, ill take a look for the beeper tomorrow, it has only just started doing it constant, before if i put it in reverse then out and back in it would clear.
klauster wrote:I have the same issue, seems to come and go though :/ will get it checked out next time I'm at Audi
mine was intermittant too, now its all the time
klauster
Post by klauster » Wed Dec 28, 2011 11:21 pm
ahh its quite annoyin when it does it, let me know what you find out pls
Rick_RS4
Post by Rick_RS4 » Fri Jan 06, 2012 9:14 pm
ordered a new speaker yesterday, fitted tonight and all working as it should again thank god, very annoying.
you dont realise how much you use the sensors
the speaker was £14, i think the cheapest part i have bought for the car
w00kie
Post by w00kie » Wed Oct 03, 2012 4:03 pm
Been a while I realise but could you let me know where abouts the speaker is and how to get to it - I think may failed the other day as it crackled for a bit and now I get the same long beep and flashes as you describe.
rich79
Post by rich79 » Sat Nov 10, 2012 5:55 pm
did u find were its located i think its in the left hand side conpartment in the boot
Tomson
Post by Tomson » Mon Oct 16, 2017 11:48 am
Hi,
Can you confirm where this is buzzer is located under the parcel shelf. I have the same fault it seems fairly common!
Tom
Users browsing this forum: No registered users and 128 guests
