Doors locking after 10mph
Re: Doors locking after 10mph
I'll post my coding when I get home. Unless someone else beats me to it that is.
Whatever your coding is, you need to add 32 to it.
However, if there is any fault with your central locking the the autolocking won't activate.
Also, it'll probably stop working after a few weeks on its own, anyway; This, even though no DTC is logged. If you clear the DTCs (even though there are none) then it'll start working again.
So before changing your coding, make sure that you have no DTCs and that you have cleared them even if there are none. This to make sure that your unit isn't already coded for it, but it's just not working.
Then you can add 32 to your coding. But make a note of the original coding, just in case.
Just been and checked my coding. My module is 4b0 962 258 N, although I doubt that's to relevant. Anyway mine is; 05887. For me this works well, boot locks as you pull away and then the door(s) lock. I'm also using selective locking or more like unlocking, a single blip and the drivers door unlocks. A double blip and the rest open.
I hope that helps.
Garry
I hope that helps.
Garry
Hi maximo me being all new to this Vagcom could you please explain how I do it start to finish I know I go into select control module then would it be central locking thanks for all your help
- Mr Footlong
Current:
Gone:
Gone:
Hi people all done used the code maximo give me (thanks maximo) I think I defo need some traing on this Vagcom
Users browsing this forum: Bing [Bot], Google [Bot] and 83 guests
