Loose steering rack
Loose steering rack
Hi people had a knocking coming from the front of the car for a while now and I've checked all the suspension over and over again but when I had the bonnet up the other day just doing the normal oil and water check my friend jumped in the drivers seat as you do and started moving the steering wheel this is when I heard a noise coming from just under the brake servo after more inspection this is the knocking noise I'm hearing I have been told by someone that this is a common fault on the a6 and a4 that the rack bolts can come loose just wanted to know if anyone else had come across this and if the bolts are easy to get to do I need a ramp or can I jack it up put it on axle stands and get to the bolts that way any info would be very helpfull the noise is driving me crazy
Re: Loose steering rack
Not heard of that one on this forum before. Sadly i can't be of any more help but you might be lucky and get Shop on here giving you all the info you need
Yeah, this is really common. Most people go through a couple of pairs of undies before they find out it's an easy fix. There are 3 or 4 bolts that need tightening up. You don't need a ramp, but *everything* is easier with a ramp.
The rack is bolted from above and below, so you'll need to move some of the gubbins out of the way like the expansion tank, etc.
Thanks shoppinit should they be torqued up to a certain tightness I have had a quick look on Vagcat there seems to be 2 on top and one underneath just trying to get as much info as poss before I tackle the job looks like il be having fun
I can't comment on the rs6 bolts but the rs4 are something like 40nm + 90 degrees.
they are stretchy bolts so best to renew rather than just tighten as they will come undone again.
perthwaRS6
i had same knock on turning wheel to the left while coming to a stop. Turned out to be steering rack bolts not fully torqued up by dealer after transmission install. Torqued up rack bolts correctly-knocking gone!
2009 RS6 sedan,5.0L FSI V10,phantom black,730bhp-98 octane,750bhp-104 octane,APR stage 1 map,MTM/Performance Friction 405mm front rotors,JCFabweld sports exhaust,MRC filters,Michelin PSS.
2011 Lamborghini Gallardo LP560-4 coupe,5.2L V10 TT UGR 800-1250whp, e-gear 6 speed,390 mm Alcon Racing front rotors, grey.
1969 E type Jaguar convertible with 5.2L 6 cylinder Rob Beere Racing engine,356 bhp-415 ft-lbs,midnight blue-old school but beautiful
The more I read posts on this forum, the more I wish I hadn't
Steering rack coming loose!
Another thing to keep my fingers crossed about!
*SOLD* - currently looking for a replacement
03 Missano Red Avant
Silver Leather, H&Rs, Dension iPod Connection kit
85k miles
85k miles
It's not all bad.
Nothing broke on my car this week
