Should I be worried
JackS4
Should I be worried
Post by JackS4 » Mon Nov 21, 2011 6:15 pm
This afternoon cruising on the motorway back to the office the yellow engine shaped light to the left of the intstrument cluster illuminated and hasn't gone off.
Car seems to drive ok and rev (no limp home etc) in both normal and MRC mode and oil and coolant temps ok...I don't have Vagcom so anyine got any ideas ?
J
Re: Should I be worried
Post by HYFR » Mon Nov 21, 2011 6:25 pm
get it scanned ASAP
EAndy
Post by EAndy » Mon Nov 21, 2011 6:44 pm
EML could be anything from something simple to something expensive. As aka_dk suggests get it checked not worth taking any chances.
Rick_RS4
Post by Rick_RS4 » Mon Nov 21, 2011 6:52 pm
where are you, someone near might have Vag Com
JackS4
Post by JackS4 » Mon Nov 21, 2011 6:59 pm
In Dublin - have rung stealers and they are going to have a look on Friday. Have never had this before and only thing I have done differently recently is that I put a Millers Eco injector cleaner in the petrol rather than my usual Redex at the weekend. Have been told its ok to drive if warning sign is yellow but don't use if it turns red :shock: .
J
scottie1979
Post by scottie1979 » Mon Nov 21, 2011 7:40 pm
Do you have audi breakdown? if so give them a call
adsgreen
Post by adsgreen » Mon Nov 21, 2011 7:48 pm
Don't think it turns red but flashes if serious problem.
The petrol cleaner could be causing some misfires which have tripped the warning.
You may find the light goes away if the fault condition issappears.
You don't need Vag Com for this - any obd reader from ebay or halfords should be able to pick up the standard codes that cause the MIL light. Whilst not as much data as a Vagcom scan it will tell you roughly what's going on and if it's a problem to be concerned about.
P_G
Post by P_G » Mon Nov 21, 2011 8:11 pm
If you have Audi Roadside an actual Audi tech will come out and diagnose during the weekday and normally clear the codes if it is not too serious. Take it to the dealers and they'll charge you an hours labour plus VAT for diagnostic.
EAndy
Post by EAndy » Mon Nov 21, 2011 8:46 pm
Good call there by P_G I'm pretty sure the AA and RAC if you have cover will also be able to read the fault codes on an OBD II reader
yoda
Post by yoda » Mon Nov 21, 2011 9:08 pm
Had the very same light on last week, it turned out to be a coilpack failure covered under warranty. Would of cost £120 if not for a £20 part :audibash:
B7RS4 Phantom Black 07 Saloon
JackS4
Post by JackS4 » Tue Nov 22, 2011 8:41 am
We don't have Audi assist over here AFAIK.
Yoda - Am guessing coil pack problem on yours would have tripped limp home mode ?
It's a weird one, car is running very well indeed after the c.260mile motorway run yesterday - unfortunately yellow light still on this morning.
Will update once on Friday once I get a view from the stealers.
J
adsgreen
Post by adsgreen » Tue Nov 22, 2011 9:14 am
Seriously - its less than 20 quid for an odb reader from any automotive Shop.
It can be anything from a fuel issue, misfire or emissions.
It can also be a small error reported frequently enough to trip the light.
edge
Post by edge » Tue Nov 22, 2011 10:01 am
best of luck with her JackS4, you going to Sandyford with her?
Pity Scatman is down the contry, hes has a Vagcom.
JackS4
Post by JackS4 » Mon Nov 28, 2011 9:27 am
Audi ran the diagnostic and found fault codes for running rich on both banks. They cleared the fault and test drove it and faults did not return. They (well they would) put it down to the remap....my suspicion is the Millers stuff that I used as never had that fault before even after 2 years of a remap.
Anyway - the car always seems to run like a scalded cat after a service :biggrin3: .
J
edge
Post by edge » Mon Nov 28, 2011 9:40 am
Good news!
You do any 3-8k runs since? I know it was down a but that was a while ago before the service.
Users browsing this forum: No registered users and 175 guests
