Re-coating peeling door handles
Hi people I know we all get annoyed will those door handles when the rubber coating starts to peel off and then starts to look scruffy well I think I have found a fix there's a product called Plastidip which can be found here www.plastidip.co.uk which is basically the rubber coating but in an aerosol can you need to strip all the old stuff off first and then just mask up around the handle apply 3-4 even coats leave to dry and problem solved hope this helps
Re: Re-coating peeling door handles
Think Shop may have already heard of that product...?
Funnily enough I had this exact same thought the other day. If you do it, please post some photos.
ive used platidip for blackening the front grill. i dont think it is strong enough to withstand sharp nails...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
neither is the OEM stuff !!!mavada wrote:ive used platidip for blackening the front grill. i dont think it is strong enough to withstand sharp nails...
Now : XFR Jag 5.0 Supercharged
Used to have : C5 Daytona Avant , silver leather , carbon inserts ; RNSE, TV in motion, Bluetooth , well filled SD card slots ; PSS9's ; Hotchkiss ARB's ; Miltek cat back res ; Wagner intercoolers ; Phaeton brake ducts ; forge DV's ;
Users browsing this forum: philS2, Steve2003rs6 and 145 guests
