Smaller antennas
mavada
Smaller antennas
Post by mavada » Tue Nov 22, 2011 3:50 pm
Where to get those smaller antennas as shown below...? Are they just replaceable by taking the old one out and new one in, or is it more complicated?
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
PhilT
RS246.com
Re: Smaller antennas
Post by PhilT » Tue Nov 22, 2011 4:22 pm
I just used a saloon one. Now it's just there to fill the hole as it is disconnected due to GPS frustration and replacement with an on dash puck.
drybeer
Post by drybeer » Tue Nov 22, 2011 5:06 pm
PhilT wrote:I just used a saloon one. Now it's just there to fill the hole as it is disconnected due to GPS frustration and replacement with an on dash puck.
How did you get around the radio reception issue?
C7 A6 allroad 3.0TDi.
Tiguan 2.0TDi R-line
Post by chunky79 » Tue Nov 22, 2011 5:56 pm
Radio is through rear side windows. The small antenna on the roof is for gps
drybeer
Post by drybeer » Tue Nov 22, 2011 6:12 pm
chunky79 wrote:Radio is through rear side windows. The small antenna on the roof is for gps
So why the huge screw-on "bee-sting" thing...
It must do something?
My GPS antenna needs replacing - and I've been hoping the smaller one would be possible, but I thought the rear windows only did one wavelength, hence I would need to keep the "bee-sting"...
PhilT
RS246.com
Post by PhilT » Tue Nov 22, 2011 6:15 pm
In my experience, the bee sting does feck all except make the car look dated :)
mavada
Post by mavada » Tue Nov 22, 2011 7:03 pm
i think this one will fit, but its expensive for a piece of rubber...
http://www.ebay.de/itm/Original-VW-Kurz ... 3a5acf4789
Yellow Koni's
Mr Footlong
Post by Mr Footlong » Tue Nov 22, 2011 7:10 pm
mavada wrote:i think this one will fit, but its expensive for a piece of rubber...
Good find if that fits well. I have a Calearo DAB aerial being fitted in to the roof directly in front of the current aerial, same angle and looks identical. I was a little weary visually about running 2 big aerials up there so that might be an option for me as I have no intention of using the TV or FM really after the DAB is installed.....
Current:
Gone:
Post by chunky79 » Tue Nov 22, 2011 9:19 pm
Took my ''bee-sting'' off cause it lokked <beep>. Radio signal = still great. If you look at the antenna body it says GPS on it
drybeer
Post by drybeer » Tue Nov 22, 2011 9:29 pm
Granted - but when I changed the antenna on my older B5 car (which looked like the same unit) it has three separate connections from memory - I thought they would be GPS, AM, and FM respectively...
So - I'll order the saloon style antenna tomorrow if I don't require the bee-sting!
Anyone else know if this logic is sound?
Post by chunky79 » Tue Nov 22, 2011 9:33 pm
You don't need the bee-sting for your radio signal mate. What headunit are you running? If rns-e/d and don't have another gps antenna then you will struggle with the sat nav
PhilT
RS246.com
Post by PhilT » Tue Nov 22, 2011 10:32 pm
Agree with the GPS connector being a PITA, hence why I went for a puck on the dash. 8 satellites :)
drybeer
Post by drybeer » Tue Nov 22, 2011 10:35 pm
PhilT wrote:Agree with the GPS connector being a PITA, hence why I went for a puck on the dash. 8 satellites :)
Yeah - I know that works - when I fitted an RNS-E to my B6 I had one of those - and to be fair it was fine...
Don't know whether to fit a puck or go for OEM to roof.
Sorry for thread-jack.
Post by chunky79 » Wed Nov 23, 2011 8:05 am
I have a puck type with my kenwood and it gets full signal. Just get a dummy antenna for the roof. I actually like the look of my oem with the ''bee-sting'' removed
mavada
Post by mavada » Wed Nov 23, 2011 2:39 pm
Yellow Koni's
Users browsing this forum: srichards and 139 guests
