MY SAMCO HOSE DOESN'T FIT!!!!
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
Ryan_s3
Post by Ryan_s3 » Fri Apr 09, 2004 12:21 pm
Hi,
Just been to put my samco air intake pipe on before my immenent re-map and the thing doesn't fit!!!I have compared it too jon murgies standard air intake pipe and it's different,the samco is the same as jon's so i have not been supplied the wrong one.My car is one of the very first s3's in this country so maybe it had a different pipe,i'm not sure??arrrhhh i'm really annoyed!!!ryan
Image360bhp 342lb/t
Ryan_s3
Post by Ryan_s3 » Fri Apr 09, 2004 12:48 pm
just found out jon's was a 2000 x 210bhp model.so it's not a 225bhp one.regards Ryan
Image360bhp 342lb/t
Ryan_s3
Post by Ryan_s3 » Fri Apr 09, 2004 3:57 pm
ok more info and help needed,talked to someone else who has a 1999 s3 and a samco fitted(didn't do themselves) and no probs as far as they know.part number for stock intake hose;
jon murgies 06A 145892 AJ / PXO 103908
mine 06A 133356 E / PXO 416482 >eco<
bit of difference there aswell.
my car seems identical to this us spec 225 tt engine bay;
http://www.battcall.com/Diverter_valve_detail_2A.jpg
while everybody elses s3 is like this;
http://www.wak-tt.com/mods/dv/dvlocation1.jpg
from what i can see there are 4 connections off the main maf to turbo pipe.
1.)pipe to actuator with sensor on(left on mine,right on eveybody elses)
2.)Diverter valve(seems to be in the same position)
3.)PCV Damper/valve(more on top on mine,more to left on everybody elses)
4.)some sort of pipe that is just before the turbo that goes across the top of the engine towards the washer bottle i think??(seems to be in the same position)
I could probably hook it up with a bit of messing with the pressure sensor and PCV.Could someone confirm that i'm right!!
thanks Ryan
Image360bhp 342lb/t
Ryan_s3
Post by Ryan_s3 » Fri Apr 09, 2004 4:57 pm
i've done a basic drawing so that it explains it better,could everyone have a look at there stock intake pipe and confirm that my guesses on the connections off the samco are correct.Main difference being the pressure sensor going to the actuator is on the left on my car and the right on everybody elses and the PCV valve is lower and more to the left,cheers for the help,regards Ryan
Image360bhp 342lb/t
Ryan_s3
Post by Ryan_s3 » Fri Apr 09, 2004 7:36 pm
it has been confirmed that the early 99 s3/tt had a different intake hose with a few different diameter/positions of the off hoses,if anyone can help with a adaption i'm sure i could supply the beer tokens ,otherwise it's back to forge.regards Ryan
Image360bhp 342lb/t
Paul-RS
Post by Paul-RS » Fri Apr 09, 2004 8:01 pm
Ryan, thats the N75 on the left on your pic.
Not seen a hose with that arrangement before.
Ryan_s3
Post by Ryan_s3 » Fri Apr 09, 2004 8:33 pm
hi Paul,
yes thats right paul the n75 is on the left side on mine as the samco is built for the n75 on the right.I wasn't told from forge that there is a difference in the hoses but they did know because i found out from the forge guy on the tt forum.I'm a bit gutted because i'm having my revo map done on the 19th and i wanted the hose sorted.regards Ryan
Image360bhp 342lb/t
sitas3
Post by sitas3 » Fri Apr 09, 2004 9:21 pm
Ryan, just looked at Etka and there seems to be a difference in the hose depending on if the car has ESP or not. Which one looks like yours??
First pic without ESP:
[img]modules/pnCPG/Coppermine/albums/userpics/10055/s3021.JPG[/img]
sitas3
Post by sitas3 » Fri Apr 09, 2004 9:23 pm
Second pic with ESP:
[img]modules/pnCPG/Coppermine/albums/userpics/10055/s3022.JPG[/img]
Ryan_s3
Post by Ryan_s3 » Fri Apr 09, 2004 9:31 pm
i would say the one without the esp,mine is a early 1999 without esp.So i think i'm screwed!!!just my luck!!thanks for the pictures wouldn't mind getting my hands on that parts program you've got,regards Ryan
Image360bhp 342lb/t
Paul-RS
Post by Paul-RS » Fri Apr 09, 2004 11:05 pm
I thought forge did one for TT's without ESP?
s8n
Post by s8n » Sat Apr 10, 2004 3:33 am
Ryan, if you want to sell the ESP version to me, provided its black. Let me know.. They are $99USD so if you come down a bit, ill grab it from you
Audi S3
Ryan_s3
Post by Ryan_s3 » Sat Apr 10, 2004 7:13 am
it's blue,it's going back to forge for a refund,ryan
unless i can adapt it.
Image360bhp 342lb/t
R88PER
Post by R88PER » Mon Apr 12, 2004 4:52 pm
Arrrrrghhhh - I've had a set of Samco's sat in the garage for a while now, after buying them of BassS3. I was planning to fit them when my car goes in for the new clutch and other bits and bobs. After reading this post I've just been and checked my hose and guess bloody what!!!
You guessed it I'm now in the same situation as you Ryan. Different bloody hose.
Any feed back you've had would be much appreciated mate.
Paul R
s8n
Post by s8n » Mon Apr 12, 2004 5:02 pm
woops :) maybe thats why it was cheap
Audi S3
Return to “S3 (Typ 8L) 1999-2003”
Users browsing this forum: No registered users and 130 guests
