My RS4 B5 3.0tt powered by LOBA Motorsport
2.7 V6 30v biturbo - 380 bhp
Arotished
Post by Arotished » Wed Oct 12, 2011 2:03 pm
Parts Ordered and in house!
Specliste ifra LOBA
LOBA LO750 turbochargers
LOBA Maahle/Pauter 3L kit with 3L crank!
LOBA Exhaust manifolds
LOBA Mechanical Camshaft
LOBA Solid Lifters
LOBA Intake/Exhaust Valves (Supertech)
LOBA Titan Retainer/Upgraded Valve-springs
LOBA EV14 750CC
LOBA Bosch 2x413
LOBA CF Airbox
LOBA CF Y-pipe
LOBA Intake pipes
LOBA Pressure pipes
LOBA MAF housing
LOBA-Sachs 1000 Nm clutch kit
LOBA 3" DP with catalysts (100CELL)
LOBA Intercoolers
General stuff!
Bilstein PSS9
380mm RS6 Front brakes/324mm RS6 Rear brakes
Hotchits swaybars (35mm front, 22m rear)
RS2 Metal Endlinks
Powerflex bushings (all over)
VAST Electric Fan Kit (medium flow)
70C Thermostat
Thermal Swich After Run Coolant Pump
Ported heads
Portet intake-manifolds
Girdle
Water/Meth Injection Kit from AEM
35PSI Boost Gauge
Innovate Due 02 Sensor Kit
034 Motorsport
034 Front upper adjustable control arms.
034 Rear adjustable Tie Rod
034 Engine mounts (Street)
034 Tranny mounts (Street)
034 Poly Snubber Mount/Backet
034 Front sway bar linkage
034 Front Subframe mounts
034 Rear Aluminium mounts
034 Aluminium reinforced driveshaft
034 Rear diff carrier mounts (Street)
034 Intake Manifild Phenolic Spacers
APIKOL Rear diff mount (Street)
JHM Motorsport
JHM Short Shift
JHM Solid Linkage Upgrade
JHM Delrin Shifter Stabilizer Bushing
JHM Linkage Cross Rod Upgrade
JHM Solid Shifter Centering Spring
JHM Soild Re-enforced Frontshaft
Overhauled transmission with reinforces 1st and 2nd sync. rings from JHM
Paint Job
Drivetrain/Suspension Job
Image'
Engine Job
Head Work
Arotished
Re: My RS4 B5 3.0tt
sonny
Re: My RS4 B5 3.0tt
Post by sonny » Wed Oct 12, 2011 2:04 pm
Very nice!
Arotished
Re: My RS4 B5 3.0tt
Post by Arotished » Wed Oct 12, 2011 2:06 pm
Arotished
Re: My RS4 B5 3.0tt
Post by Arotished » Wed Oct 12, 2011 2:07 pm
Re: My RS4 B5 3.0tt powered by LOBA Motorsport
Post by bam_bam » Wed Oct 12, 2011 4:21 pm
Not enough pictures.
PORN!
That man is a PORNSTAR.
davs4
Post by davs4 » Sun Oct 16, 2011 6:23 pm
That looks amazing more pics please :thumb:
RS4KILLA
Post by RS4KILLA » Tue Oct 18, 2011 3:39 pm
well done amazing!
B5 S4 KO'4 black saloon sunroof......
B5 RS4 Goodwood Green,sunroof, nav tv, short shifter,
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
Timster
Post by Timster » Tue Oct 18, 2011 7:23 pm
Jeebus.
Well done. I so wish I had the space/funds/time and skill to do all this.
(I bet you have "a" screw left over)
Arotished
Post by Arotished » Sun Oct 23, 2011 11:45 am
wrekka
Post by wrekka » Mon Oct 24, 2011 8:00 am
Wow that is all fantastic! As said above wish I had the skill to do this!
TTS RS4 -amazing machine,
Previous:
Arotished
Post by Arotished » Tue Feb 21, 2012 9:26 am
Arotished
Post by Arotished » Tue Feb 21, 2012 9:34 am
PhilT
RS246.com
Post by PhilT » Wed Feb 22, 2012 12:24 pm
That's impressive work. Is it passion or a business? I wish I had the time to do this to my RS4 :)
Post by bam_bam » Wed Feb 22, 2012 12:31 pm
Arotished wrote:Image
^ Is that to stop small children being sucked into the engine?
Users browsing this forum: Majestic-12 [Bot] and 3 guests
