On Thurs on may way home from work a huge chunk of chipboard fell off a delivery truck and shattered while on the freeway/highway...I could not avoid it and went straight over it and felt it crumble under my car...didn't seem to bad...prodded the throttle and heard that hiss indicative of a large boost leak along with the customary hesitation. Nursed the car home and found the pipe from the turbo to left cooler had been knocked loose...didn't think too much of it.
Reconnected the pipe today and tried to fire her up..she swings over freely and almost takes but then nothing...just keeps swinging over..I checked the mafs, all the piping everything obvious and can't see anything.
Vag Com gives me the following errors
17861 - Exhaust Gas Temp Sensor 1 (G235): Open or Short to Plus
P1453 - 001 - Upper Limit Exceeded
17740 - Knock-Control: Cylinder 8: Regulation Limit Exceeded
P1332 - 001 - Upper Limit Exceeded - Intermittent
17735 - Knock-Control: Cylinder 3: Regulation Limit Exceeded
P1327 - 001 - Upper Limit Exceeded - Intermittent
17739 - Knock-Control: Cylinder 7: Regulation Limit Exceeded
P1331 - 001 - Upper Limit Exceeded - Intermittent
17473 - Fuel Pressure Regulation: Regulation Discrepancy
P1065 - 008 - Implausible Signal
17734 - Knock-Control: Cylinder 2: Regulation Limit Exceeded
P1326 - 001 - Upper Limit Exceeded - Intermittent
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 001 - Upper Limit Exceeded
17538 - Fuel Trim; Bank 2 (Mult): System too Lean
P1130 - 001 - Upper Limit Exceeded
I know before the incident there were no fault codes. Im thinking its a fueling issues, maybe the fuel lines under the car got damaged..the fuel guage shows a quarter tank and i can't see any damage to the lines...there are scratches on the tank though...
any Ideas?
