Well thought id ask the question to see if its a common thing...
When i first start the car at any time, the first time i hit the brake it seems to sink way lower than it does when i apply it right after. But after that initial first time its never as bad.
Almost like theres some sort of floating disc problem, or a leak?...
just want to put it out there incase im worrying over nothing... or its a serious problem!~
Thanks in advace.
Mark
Sinking brake pedal
Re: Sinking brake pedal
Over servoed or leaking fluid, mine does it and the second stab is always firmer.
Not a disc problem I think.
When you change pads and push the pistons back the first couple of brake pumps do this.
Could be a vacuum problem - the fact it is fine after this doesn't suggest leaking fluid.
You may have or had air in the system - ever boiled the fluid? How Old is the fluid?
Worth a fluid change to see if it sorts it.
Users browsing this forum: Majestic-12 [Bot] and 191 guests
