De-coke Done
adsgreen
Re: De-coke Done
Post by adsgreen » Mon Oct 10, 2011 8:07 pm
Realistically the power flap will be marginal to notice coke or no coke.
Bigger factors are cam change over and throttle limiter.
lengster1
Re: De-coke Done
Post by lengster1 » Mon Oct 10, 2011 8:13 pm
Thought it was the other way around,airbox flap only opens in 3rd gear onwards when there sufficient airflow? Full throttle and torque is knocked back until 3rd onwards,pretty useless for real world driving hence my MRC Tuning to get full pops when you actually need it,the kick is associated with the airbox flap opening so if youve lost it then it may well be a vacuam issue with the flap itself (mine suffered this) but carbon build up has the most effect in the high rpm range also according to my dyno plots
Dave_M
Re: De-coke Done
Post by Dave_M » Mon Oct 10, 2011 8:48 pm
Thanks P_G - knew there was something else that happened at 5500rpm - throttle is restricted to 60% in first 3 gears until 5500rpm when 100% is provided. Same logic applies though.
Both my airbox flap and intake manifold flaps operate correctly under VAG-COM. The car used to have a quite pronounced kick at 5500rpm when I first got it 18 months ago, but alas no more - it disappeared several months ago and the power now feels totally linear right up to the red line.
Strange thing is it still pulls a c 8.2s time for the 3000rpm tp 8000rpm test.....
Dave
2007 B7 RS4 Daytona Avant (the daily driver)
Other current toys: 210bhp Caterham 7 (track toy), 1994 380bhp Escort Cosworth Monte (awaiting engine rebuild), MX5 1.8 Sport (strictly my wife's!)
Gone: Nissan 350z roadster, 205 GTI Mi16, Classic Impreza 2000 Turbo, Nissan Sunny GTiR, Corrado G60, 205 GTI 1.9, Rover Metro Gta (don't ask!), Escort 1.6i cabbie, MG Metro (first car)
adsgreen
Re: De-coke Done
Post by adsgreen » Mon Oct 10, 2011 9:09 pm
Air box also opens at 5500 or over a high speed (100 mph or so) irrespective of gear.
You can still have a vac leak even though the tests are ok. The only way to confirm is to hook a vac/boost gauge and take some readings.
Scatman
Re: De-coke Done
Post by Scatman » Mon Oct 10, 2011 9:43 pm
I lost the 'kick' after 5,500 and turns out the solenoid that controls the airbox flap was cracked and leaking vacuum... Exhaust flaps were still working fine and manifold flaps were passing the test sometimes and failing on other tests.
SKG_C63AMG
Re: De-coke Done
Post by SKG_C63AMG » Tue Oct 11, 2011 1:05 am
adsgreen wrote:Realistically the power flap will be marginal to notice coke or no coke.
Well thats strange because i lost my 5500 rpm kick a while ago, fittes a Gruppe M and it didnt return but yet done a full carbon clean, didnt change the one way valve under manifold so only a carbon clean and my 5500 rpm kick returned and is proven also by my recent map done by doug at MRC, so carbon clean=5500rpm kick :biggrin3:
sorry forgot to mention my stage 2 ported manifold with flaps removed and vains left connected but ported but my kick is still there where as before carbon clean it wasnt, also the Gruppe M bypasses the airbox flap!
LATEST C63 AMG
FOCUS RS MK2 (now gone as well)
gone but not forgotten - B7 RS4 CABBY
PREVIOUSVW GOLF MK5 R32
EVO 8
SUBARU 03 WRX
SAPHIRE COSWORTH 2WD built by my own hands
VW GOLF MK5 GTTDI
EVO 8 (again)
SEAT LEON CUPRA R
VW GOLF GTI 1.8TURBO MK4
BMW 318 E36
SAXO VTR X2
2manytoys
Re: De-coke Done
Post by 2manytoys » Tue Oct 11, 2011 7:54 am
I've said this before; Log timing (and rpm/air temp/timing correction) and you will see what is going on. Cheers
PetrolDave
Re: De-coke Done
Post by PetrolDave » Tue Oct 11, 2011 5:22 pm
SKG_RS4 wrote:carbon clean=5500rpm kick :biggrin3:
Provided ALL the other conditions are correct too - it really isn't as simple as just carbon clean.
Users browsing this forum: No registered users and 169 guests
