fried eggs
S4Paul
fried eggs
Post by S4Paul » Mon Oct 10, 2011 8:50 am
Do you really need to take the car into the garage to get the orange bulbs swapped out for silver (flash orange) bulbs?
I have had a look into the tight :audibash: engine bay and can see the 2 x light covers for the Xenon, high beam and side lights but cant see how you can get to the front indicator bulbs :? anyone know of a trick to sort this out :bowdown:
I can see that the air intact duct will need to come off on the off side but still cant see how after that?
I have look around the site and can only find details on older units with orande lens which need to be but in the oven?!?
this must have been done by all with a B6?
:beerchug:
Paul
S4 Avant / black / manual 6sp / RNS-E / Silver Recaro's
goose
Re: fried eggs
Post by goose » Mon Oct 10, 2011 11:15 am
The Revolution guys do this job quite a lot I believe...
http://www.revolution247.com/rs4-phase-2-85657-0.html
goose
Current:
'08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
'72 Sunburst Yellow VW Karmann Ghia Coupe|1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 interior
Past:
'06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
S4Paul
Re: fried eggs
Post by S4Paul » Mon Oct 10, 2011 9:16 pm
i could not believe you have to take the complete headlight out to change the indicator bulb.........
before
remove
after
Paul
Rick_RS4
Re: fried eggs
Post by Rick_RS4 » Mon Oct 10, 2011 10:21 pm
on the B7 you can get to it from behind by removing a couple of screws in the arch linerand reaching in, 15 min job each side id say the B5 would be the same.
S4Paul
Re: fried eggs
Post by S4Paul » Tue Oct 11, 2011 12:33 am
Rick_RS4 wrote:on the B7 you can get to it from behind by removing a couple of screws in the arch linerand reaching in, 15 min job each side id say the B5 would be the same.
I guess you could do the same on the B6 but either way 15mins when you just want to reach in twist and change :rant:
Paul
hlbeckley
Re: fried eggs
Post by hlbeckley » Tue Oct 11, 2011 2:50 pm
My car was getting a service and the chap was replacing the snub mount, i quickly rushed around with the new bulbs and a full set of interior LEDs
I did the interior but dealer did the indicator bulbs whilst the head lights were out. They need an internal clean though, but too hard for me to do.
sonny
Re: fried eggs
Post by sonny » Tue Oct 11, 2011 5:03 pm
You could just use a can of black spray to cover them up? I saw this on a B7 RS4 at ADI.
btw im joking, it looked <beep>!
