That is why we go for the ester-based Fuchs Pro-S.Sulli wrote:In fact I didn't have chain rattle on longlife, I do on 5w40??? I didn't expect this, in fact most people report that change to 5w40 can eliminate chain rattle, no produce it. Bit confused by this.
Oil Choice S4 B6
- cobraBLACK
Re: Oil Choice S4 B6
Audi S4 Avant (B6, 2004) in Goodwood Green.
It's the Ester base that's the magic ingredient in Fuchs.
I'm having my engine, gearbox and rear diff oils done this week. Along with brake fluid and fitting my sump guard. Be interesting to see the difference the fresh gear oils make
Having mine serviced on Friday, got the Fuchs oil on it's way to the garage already
S5 Coupe, V8 on 20's with ContiSport rubber
- cobraBLACK
The gearbox fluid change was very noticeable on mine but it's still notchy as hell so I'm gonna pick up the JHM short-shifter soon.xyber wrote:It's the Ester base that's the magic ingredient in Fuchs.
2 things, Audi longlife isn't ester-based. It's stopped nowbiyitch wrote:That is why we go for the ester-based Fuchs Pro-S.Sulli wrote:In fact I didn't have chain rattle on longlife, I do on 5w40??? I didn't expect this, in fact most people report that change to 5w40 can eliminate chain rattle, no produce it. Bit confused by this.
Daytona RS6 saloon, KW v3s, Hotchkiss ARBs, Milltech non res, MRC
CI Granduca Motorhome!
From my experience of short shifters, they will make the amplify any notchiness in the gear change so fitting may make the symptoms worse.The gearbox fluid change was very noticeable on mine but it's still notchy as hell so I'm gonna pick up the JHM short-shifter soon.
Pete
