Misc 1.8t big turbo build parts
jc..
Post by jc.. » Fri Oct 07, 2011 9:29 am
I am splitting a build I was hoping to fit this winter. mainly because I am broke!
aside from the 2.0l 20v stroked AJL block (see other thread for spec)
Many parts transferable between any B5 A4, some specific to the 1.8tqs
I have the following for any B5 -
034 font snub mount and poly bush £40
034 Front subframe bushes £100
034 (1.8t) gearbox mounts £60 (£170 for all of these together)
Bosch 044 Motorsport Rally spec pump + drop in cage and housing £160 (this is the higher flowing rally spec not you bog standard 044 bought from MRC)
Custom TTV 240mm flywheel S4 size with 1.8t bolt pattern £175
Southbend stage 4 S4 clutch (good for 600ft/lbs) £650 (clutch and flywheel together for £750, over £1200 to buy these new)
Tial 44mm Vband Wastegate £200 (with all clamps)
034 gearbox mounts £60 (£170 for all of these together)
AEM AFR gauge with Lamda sensor £120
AEM Trueboost Electronic Boost controller £200
For the 1.8t A4
oversized OEM inlet manifold (2" wider that stock with all stock fittings) £45
Agtronic tubular VBand exhaust manifold (with or without a Tial GT28xx Vband exhaust housing) - £1000 with exhaust housing/coolant/oil lines (I have origianl receipts for over $2000)
Stock VAG Panel Filter £7
Oversized Oil Filter £5 (£7 posted)
VAG Green Top Temp Sensor £5
VAG Water pump belt £5
All parts are in original packaging where appropriate, brand new and unused
Prices include shipping to mainland UK
please email for pics or text
ed(at)ersg(dot)com
07947429616
thanks
