Rough running when cold
spikeyboy101
Hi guys,
My car has been running a bit rough when cold - spoke to Audi about it when i had the coil packs done, but typically of Tonbridge Audi they wernt keen on looking at the software version on the car or doing the update to SW0090
Now the temps are dropping a bit the rough running is worse, so going to speak to Tonbridge Audi again and instist it is done, however a couple of questions:
1) is this done free by Audi or is there a charge normally ?
2) Going to be getting a AMD remap in a couple of weeks (once the Milly is in stock) will the AMD remap cure the rough running when cold, or do i still need the SW0090 update, and to be done prior to the AMD map ?
Finally when speaking to AMD about their map they said it doesnt as standard remove the torque limit in gears 1, 2 and 3 but they can remove if i wish, however they said it could damage the gearbox - should i have any fear it will damage the gearbox ? or is it safe to have the torque limits removed ?
Thanks guys.
Thanks guys.
Re: Rough running when cold
Spikey,
100% get the software update before the remap as the update will clear your map back to stock.
Audi will charge you for anything.
Not sure if the remap will cure the rough running.
Had my map for 6 weeks with no torque limiter and no issues as yet.
Good luck mate.
Good luck mate.
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
- PetrolDave
You normally have to give an "acceptable reason" to get the 0090 SW update - smoky starts and rough running when cold are usually the "magic words".
..... and don't forget the word "kangaroo-ing" as well.PetrolDave wrote:You normally have to give an "acceptable reason" to get the 0090 SW update - smoky starts and rough running when cold are usually the "magic words".
Plus what Dave said.
spikeyboy101
Thanks guys - will use the magic words (although these are my cars symptoms anyway)
Will see what tonbridge audi say.
- Revolution
- Trader (Expired)
I had the SW0090 recall done, plus new coil packs and plugs and mine still runs rough when cold.....no faults on Vagcom either......pain in the bum
http://www.revolution247.com
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
Sold but never forgotten:
2014 RS4 Sepang Blue
2015 VW Golf-R
2012 RS3 Sepang Blue
RS4 B7 Avant Daytona
2002 Renault Avantime V6
2006 2-door Impreza STi
2009 TT TDi Quattro
10 Subaru's inc 22B type UK
Renault Clio V6 MK2
Civic Type-R's Mk1, 2 and 3
205 GTi 1.6 & 1.9 Gutmann
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
- PetrolDave
It's not a recall (those are only for safety issues and organised through VOSA http://www.vosa.gov.uk/vosa/apps/recall ... sp?tx=VOSA), and it's not even a Workshop Campaign as it's an "on request" free upgrade - provided certain conditions are met.Revolution wrote:I had the SW0090 recall done
- Revolution
- Trader (Expired)
...good point, learn something new everyday. - still a pain though
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
Must be that North East air............Revolution wrote:...good point, learn something new everyday. - still a pain though
- Revolution
- Trader (Expired)
LOL...it is fresh...and clean...
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
Too rich a mixture until oil temp reaches 60 degrees, then you'll find it runs smoother so I would suspect a mixture program associated with the engine rev limiter protection program. I also notice my fuel gauge improves marginally after this phase.Revolution wrote:I had the SW0090 recall done, plus new coil packs and plugs and mine still runs rough when cold.....no faults on VAGCOM either......pain in the bum
- Revolution
- Trader (Expired)
nice one P_G
next job to tackle
next job to tackle
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
As above. Get SW0090 then AMD remap.
- Revolution
- Trader (Expired)
"cough" had SW0090 and Revolution Remap next...sonny wrote:As above. Get SW0090 then AMD remap.
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
Also try a injector cleaner such as Redex or Wynns, give the car a service (if it needs it) also inspect the air filter.
The AMD remap I am guessing will be a generic remap and not a custom one (could be wrong).
Users browsing this forum: No registered users and 349 guests
