A6 3.0TDi Fault Codes Help Please
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
Iain_S4
Post by Iain_S4 » Wed Aug 31, 2011 9:26 pm
First time user of VCDS - found out my neighbour has a lead so can see me borrowing it frequently. Can somebody please help me with the following fault codes from the wife's 3.0TDi A6. Are these anything to be concerned about? I'm assuming there are not as the engine emissions light has gone off again after being on for a while. Can someone please confirm?
3 Faults Found:
005660 - Glowplug for Cylinder 3 (Q12): Open Circuit
P161C - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Mileage: 79356 km
Time Indication: 0
Date: 2010.06.01
Time: 08:45:19
Freeze Frame:
RPM: 903 /min
Torque: 132.6 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.76 V
Duty Cycle: 24.1 %
Temperature: 9.9°C
005504 - Throttle Actuator (Bank 1): Malfunction
P1580 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 0
Fault Frequency: 3
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Voltage: 11.78 V
Duty Cycle: 89.6 %
004120 - Intake Manifold Runner (Bank 2): Lower limit not reached
P1018 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 37
Mileage: 82746 km
Time Indication: 0
Date: 2010.07.22
Time: 22:10:49
Freeze Frame:
RPM: 756 /min
Torque: 140.4 Nm
Speed: 0.0 km/h
Voltage: 13.53 V
Duty Cycle: 80.9 %
Duty Cycle: 88.8 %
Duty Cycle: 80.9 %
grizz
Re: A6 3.0TDi Fault Codes Help Please
Post by grizz » Thu Sep 01, 2011 6:56 pm
All common faults ,
The intake manifold will need to be replaced , the Throttle body will have worn out and 1 dead heater plug ..
Grizz
Unit 20
0151 3366888
Iain_S4
Post by Iain_S4 » Thu Sep 01, 2011 10:21 pm
oh b*****!!! sounds expensive, especially the inlet manifold part
grizz
Post by grizz » Thu Sep 01, 2011 10:34 pm
The manifold is plastic , Off the top of heads it's £320 + vat ..
If you pm your reg number i can get you the exact price ..
Unit 20
0151 3366888
Iain_S4
Post by Iain_S4 » Thu Sep 01, 2011 10:39 pm
Just popped back on here as I forgot to say thanks for the reply above. Thank you. PM with reg no is on the way
Return to “DTC / VCDS”
