Can anyone with the front badge fitted please take a picture of it from inside the grille please?
I have the badge, I have the clips but the two don't seem to meet.
Thank you.
S4 Grille badge fitment
Re: S4 Grille badge fitment
The badge sits on the grill and locates on a lug at the rear or the slat. Then the panel clips slide each side of the lug and clamp the badge to the slat
Just had the same thing with my S4 (B6). The badge is rhombus shaped, but the grille has square vents so I've had to sit mine against the grille with the two metal clips holding it on from the back, whereas I would have thought it should sit snugly within the slats of the grille.
-Ben
-Ben
mine sits perfectly within one of the openings in the grille
Got it now. I had the wrong grille badge so it was never going to fit right.
The correct one sits inside one of the square openings, the one with the location lug at the rear of the lower horizontal bar. It located itself very easily on this lug then the clips came in from the back to hold it in place. All very self explanatory with the right badge
