Hi again,
I didn't want to ask as it should be obvious but I have another simpleton question:
I have installed Nav.tv's NAVAVT av input harness on to the back of the tv tuner. All it is is an extension to the existing 54 pin plug which includes 6 RCA leads with female connectors, two each for right audio, left audio and video.
Now that I have plugged it in I'm at a bit of a loss. As the av signal is being delivered to the head unit via the tuner all I should have to so is point the head at the tuner, select the av input from the tuner and watch / listen. I'd assumed the av options would appear when scrolling through the tv channels but no. Nav.tv say the av inputs should appear in the channel / frequency list.
Do I need to so something with the tuner to get it to see the inputs?
Is it like tv scart where you have to give it a hi/low singal to automatically switch to it?
Confused in my brain.
Anyone any ideas?
Thanks!
Tv tuner enable av?
Danrowland
Re: Tv tuner enable av?
In case anyone's interested all you have to do is press setup when pointing at the tuner and choose AV1 or AV2!
Easy as that.
Easy as that.
333/999
