Ross-Tech
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
PhilT
RS246.com
Ross-Tech
Post by PhilT » Fri Aug 01, 2008 11:40 am
For those of you who would like to purchase VAG-COM (VCDS), here is the website:
http://www.ross-tech.com/
To order, use this link http://www.ross-tech.com/Merchant2/merc ... ode=VAGCOM
Item Descriptions:
VCDS Super Professional Kit
Everything a busy shop needs to turn two PC's (one with an available USB port and one with an available Serial port) into powerful diagnsotic tools for VW, Audi, Seat, or Skoda automobiles. The Super Pro-Kit gives the technician a handy carrying case with all the items needed including:
* HEX-USB+CAN Interface,
* HEX-COM+CAN Interface,
* 2x2 adapter for older cars,
* USB extension cable,
* Serial extension cable,
* VAG-COM software on CD-Rom,
* and a full color printed manual.
VCDS Professional Kit - USB Interface
Everything a busy shop needs to turn any PC with an available USB port into a powerful diagnsotic tool for VW, Audi, Seat, or Skoda automobiles. Pro-Kits give the technician a handy carrying case with all the items needed including:
VCDS Professional Kit - Serial Interface
Everything a busy shop needs to turn any PC with an available Serial port into a powerful diagnsotic tool for VW, Audi, Seat, or Skoda automobiles. Pro-Kits give the technician a handy carrying case with all the items needed including:
VCDS License with HEX-USB+CAN Interface
The professional's interface you need to turn any PC with an available USB Port into a powerful diagnostic tool for VW, Audi, Seat or Skoda automobiles.
Features:
* Works with all diagnostic-capable VW/Audi cars in model years 1990 through 2008, even the latest models which require a direct CAN connection for diagnostics
* Acts as a "dongle" -- Activation for the full-function version of VAG-COM is built in! Use VAG-COM on any suitable PC, no activation codes required.
VCDS License with HEX-COM+CAN Interface
The professional interface you need to turn any PC with an available Serial COM Port into a powerful diagnostic tool for VW, Audi, Seat or Skoda automobiles.
Features:
* Works with all diagnostic-capable VW/Audi cars from 1990 through 2008, even the latest models which require a direct CAN connection for diagnostics
VCDS License with Micro-CAN Interface
The enthusiast's interface you need to turn any PC with an available USB Port into a powerful diagnostic tool for MK5 based Golf Technology Models.
Features:
* Low-cost interface designed exclusively for use on cars based on Mk.5 Golf technology. This interface is not backwards compatible with older cars using K-lines for diagnostics, and it is not compatible with some Audi models. See the Micro-CAN technical page for a list of compatible models.
* Acts as a "dongle". No "Software Activation" required! When used with this interface, VAG-COM is always fully-functional on any PC that meets our requirements.
* USB connector plugs into most modern laptops! (USB 1.1 or 2.0)
* Bi-Color (red/green) status/activity LED
* 12 month guarantee against defects.
VCDS License with KEY-USB Interface
The enthusiast's interface you need to turn any PC with an available USB Port into a powerful diagnostic tool for VW, Audi, Seat or Skoda automobiles.
Features:
* Works with most cars using a single K-Line, K+L, or dual K-Lines for diagnostics. (Does not work with some 2003+ cars using CAN for diagnostics.)
If you need compatibility with the latest cars using CAN for diagnostics, you should order a HEX-USB+CAN Interface instead.
To see if a KEY-USB will work with your car, check the Vehicle Applications Chart for more information.
VCDS License with KEY-COM Interface
The enthusiast's interface you need to turn any PC with an available Serial COM Port into a powerful diagnostic tool for VW, Audi, Seat or Skoda automobiles.
Features:
If you need compatibility with the latest cars using CAN for diagnostics, you should order a HEX-COM+CAN Interface instead.
To see if a KEY-COM will work with your car, check the Vehicle Applications Chart for more information.
VAG-COM Software License
If you have a third-party interface and want the full-function version, you need a license and the attendant activation code.
VAS 5051/2 "2x2" Adapter for Older Cars
This adaptor connects between the 2x2 port in older (1990-1995 pre-OBDI) vehicles to the OBDII connector used for current generation diagnostic tools.
These are exactly the same as VW's VAS-5051/2 adapter.
bigsteve
Re: Ross-Tech
Post by bigsteve » Sat Aug 27, 2011 11:47 pm
Merchant link no longer works did it give a discount on the purchase price ?
Steve
Life is like petrol, the more you put in, the more you get out.
Return to “DTC / VCDS”
