I'm not saying you lost 10% torque, I think the readings are wrong...P_G wrote:Just a thought, if there is no vacuum in the system would this affect the compression test as this was doen when the vacuum was pinched?
I don't think vacuum would matter, it's just a mechanical pumping test basically
the bmep of 188 is with the engine at the sweet spot, vol eff >1
the comp test the vol eff is lower becasue the engine is turning slower
anyone with the shp manual? what is the spec?
I'm guessing 175-180 range
