Guys
I picked up a genuine Ross-Tech cable from a forum member a while back, just got round to having a play and already stuck, when I run an initial test, on COM1, I get message stating 'interface not found'
I am running VCDS 10.6 on my laptop, I've tried in both ON and IGNITION ON mode, I connect Hex to car port first then to USB in laptop, what am I doing wrong? Do I need to subscribe with Ross-Tech for another $99!?
Nils
Help, first time using vagcom, cannot connect
Re: Help, first time using vagcom, cannot connect
Hi Nils.N11LS_J wrote:Guys
Nils
IIRC... doesn't it show USB on the VCDS screen as an option to pick ? (not Com1, which was the old serial port model/ dummy USB)
Edit: I've just checked:~ Select Options > USB > then click on Test.
I thought that, so tried USB too, no luck, I'm sure it's something really simple I'm doing wrong but getting frustrated now!
Instagram : n_i_l_s
Take it outside your car and whack it on the curb (bit like you were trying to kill a snake) !N11LS_J wrote:I thought that, so tried USB too, no luck, I'm sure it's something really simple I'm doing wrong but getting frustrated now!
Failing that. Again, from memory..... ignition off & VCDS not running.... > plug cable into car > plug other end into USB socket > Run VCDS > Igniton to ON (but don't start engine) > Check that USB is hi-lighted as before > Click Test.
If it doesn't work.... DON'T touch anything.... just leave it a few mins.... then click Autoscan.
See if that works (I sometimes have to wait a while for mine to wake up)... you ask the missus about it phnaw phnaw.
Any Luck?
Users browsing this forum: No registered users and 31 guests
