More goodies for the RS *Pole positions now in with pics*
sonny
Re: More goodies for the RS *Pole positions now in with pics
Post by sonny » Mon Jun 27, 2011 11:25 pm
stumpyrs4 wrote:CG Locks are fantastic for those wanting to feel more secure in the car. Also help with back aches, as the device holds your lower back much better in the seat.
Do you have one for the passenger seat to?
adsgreen
Post by adsgreen » Tue Jun 28, 2011 9:16 am
I personally am very wary about fitting a device on the seatbelts. Given that the belts are designed to be used in conjunction with explosive pre-tensioners and a loose belt then I'd be worried that with the belt already held taught you are going to be putting more force through it than it was expecting.
The only testing shown on the CG lock site has been at 20 and 35 mph - pointless given that any track incident will happy and multiples of this speed in addition to a potential roll over scenario.
Every serious accident I've seen on track has not been a single isolated incident but general a series of separate discrete impacts and without this kind of testing I wouldn't want to fit one and potentially compromise safety.
It's also an interesting comparison between normal 3 point belts and harnesses - 3 point belts are design for generally low speed single collisions and stretch a huge amount to reduce the forces on the users. It's why pre-tensioners are essential on modern belts. Harnesses however are designed to keep the occupants in the car at all costs and because of this the webbing/weave of the belts is different with minimal stretching designed in. Ironically you are more likely to be injured wearing harnesses (collar bone is common) as they don't reduce the forces on the occupants like a 3 pointer but less likely to be ejected from the car even after multiple impacts.
sonny
Post by sonny » Tue Jun 28, 2011 9:23 am
Its only the lap belt that is tight, the shoulder strap is lose as it would, so it still has movement. I understand where you are coming from, as I was in (and still am) in two minds.
adsgreen
Post by adsgreen » Tue Jun 28, 2011 12:11 pm
ah, ok so thats not too bad. Ironically I've seen people on track fixing this into the shoulder strap pulling the whole thing tight which always did worry me.
I don't have many problems moving about in the buckets - pretty snug for me.
Be tempted with the scroth quick fit belts - just working out how to fix the mounting point on the right side as the reason it's not compatible with the b6/b7 platform is that there isn't a discrete mounting point for the belt but rather it's built into the seat (which suggests the seat mounting points should be strong enough).
Be nice to use the bucket shoulder cutouts rather than just for show ;)
sonny
Post by sonny » Tue Jul 19, 2011 6:19 pm
I now have a two seater Saloon :thumbs:
Removed rear seats and boot contents out today.
In the Saloon the seats act as a sound deadening. All I can say is, what a racket the noise is!
The exhaust burble is great on lift off though ;)
Iv not had a chance to weight them yet, but I reckon I have saved about 25kg/30kg.
PJC
Post by PJC » Tue Jul 19, 2011 6:22 pm
I take it that is for Cadwell, how much weight came out?
sonny
Post by sonny » Tue Jul 19, 2011 6:23 pm
PaulRS4 wrote:I take it that is for Cadwell, how much weight came out?
Cadwell, Spa and the two Ring trips. Not sure yet not weight, think around 25/30kg.
PJC
Post by PJC » Tue Jul 19, 2011 6:29 pm
Every little helps.
Revolution
Trader (Expired)
Post by Revolution » Tue Jul 19, 2011 6:37 pm
sonny
you need a harness bar and some harnesses to finish that off.....give Glen a ring in morning and mention "Lee with the subaru" as he is flogging his harness bar and i have harnesses here for you......
Glenn
http://www.revolution247.com
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
Sold but never forgotten:
2014 RS4 Sepang Blue
2015 VW Golf-R
2012 RS3 Sepang Blue
RS4 B7 Avant Daytona
2002 Renault Avantime V6
2006 2-door Impreza STi
2009 TT TDi Quattro
10 Subaru's inc 22B type UK
Renault Clio V6 MK2
Civic Type-R's Mk1, 2 and 3
205 GTi 1.6 & 1.9 Gutmann
sonny
Post by sonny » Tue Jul 19, 2011 6:44 pm
Ok just had a weight in. Total amount 39.3kg (87.9lb)
Rear bench (bottom) 5.5kg
Back seat right side 18 kg
Back seat left side 7.8kg
Boot contents and seat belt brackets 8kg
Combined with the 2 pole positions and frames, total weight saved is 59.5kg. (131.2lb)
EDIT. Including track day rims, a further 20lb (9.1kg) Unsprung weight has been saved.
No I start my rice diet, looking at shedding 40lb myself... :jump:
Not a bad weight saving, more than I was thinking.
PJC
Post by PJC » Tue Jul 19, 2011 6:47 pm
Revolution wrote:sonny
Glenn
Good idea.
adsgreen
Post by adsgreen » Tue Jul 19, 2011 7:19 pm
Now you want to relocate the battery to behind the front seats ;)
Post by HYFR » Tue Jul 19, 2011 7:40 pm
60kg is superb mate
most manufacturers do that and charge a £20k premium
S4Player
Post by S4Player » Tue Jul 19, 2011 8:19 pm
Good weight saving mate the Americans said the rear seats came in at 100 pounds so they weren't far wrong
sonny
Post by sonny » Tue Sep 27, 2011 10:08 pm
aka_dk wrote:60kg is superb mate
Its now a RS4 GT :beerchug:
Finally got round to replying to my own thread!
Users browsing this forum: Majestic-12 [Bot] and 120 guests
