As the title says, can you measure (air fuel ratio) AFR with VAGCOM? To see if your car is running lean specifically?
Dunc [img]images/graemlins/s3addict.gif[/img]
Can you measure AFR with VAG COM?
I seem to remeber a post on vortex about this - using lambda voltages and other stuff
You need to use this XL sheet:
http://home.earthlink.net/~cogent001/vw ... XAMPLE.xls
see:
http://forums.vwvortex.com/zerothread?id=369614
http://forums.vwvortex.com/zerothread?i ... 6#11381196
Hope that helps!
Cheers,
Jon
see:
Hope that helps!
Cheers,
Jon
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
