Dyno Test - low on power, what next..?
P_G
Re: Dyno Test - low on power, what next..?
Post by P_G » Sat May 21, 2011 9:13 pm
Not necessarily, as you know in third which this dyno run was done on there is the combination of air box flap and torque limiter removed. It could be that on the road the surge is felt but is this the same surge as in other cars, some people have expressed partial opening of the flap. Plus if there is insufficient airflow in the first place it will affect the top end much in the same way as occlusion as you would have it by carbon build up.
Plus IIRC the figure was 338.6 at the crank which is only 10bhp (3%) less than my lowest Dyno Dynamics figure and 30bhp (8%) less then my best. Yet like I said before my car can make 400+ bhp on a Dastek road with the same car and can run 8.2-8.5 second 3k-8krpm tests. So between Shoot mode, fuel and airflow certainly creditable.
sonny
Post by sonny » Sat May 21, 2011 10:08 pm
lengster1 wrote:Daz rs4,does it always kick in the higher gears? Or have you had it feel flat like in the earlier gears and no extra induction roar so to speak? The airbox flap has been known to be ill fitting and need a fettle (neckarsulms i think) if it does intermitently kick which you havent said it does.Go on mrc website and look at the power plots and compare yours you will see what i mean.
Use this power plot if you wish :bigblink:
lengster1
Post by lengster1 » Sun May 22, 2011 12:34 am
Thanks sonny,do you see what i mean now? My car was the same before cleaning although not to the same degree it made 379 in fourth with a full milltek system inc cats,my graphs are near identical to sonnys when i had that spec (maybe a couple of bhp down to be excact) but i then replaced the sports milltek cats with no cat downpipes and cold air induction mod and the manifold further reworked and stage 2 map which gives an even more linear power delivery all the way to 8k+ and substantially more torque,a trip to mrc would cut out all the various rolling road b*llocks as its directly comparable with many other benchmark b7s,i do accept there are variables when rolling road tests are done but i do think a car that made 338 is far enough out to suggest a problem greater than fuel etc
DazN
Post by DazN » Sun May 22, 2011 12:28 pm
My car currently has 53k on the clock and has been serviced at Audi twice, 17,500 and 36,000, it did have an oil change when I bought it but that wasn't from Audi.
On both the Audi services it only had oil changed and on the 36k it had air filter too.
I'm suspecting it might need the plugs changing and a 'proper' service, I suppose Grizz from Unit 20 is the best man to do this!!
Audi S4 (B9)
Gone:
C63 Coupe (2014)
Audi S4 (B8)
BMW M3 (E90)
Audi RS4 (B7)
BMW M5 (E60)
BMW M3 (E46)
DazN
Post by DazN » Tue Jun 07, 2011 12:56 pm
Resurrecting this thread because the car's at Unit 20 now.
Airbox flap was stuck so that's been freed, also had a full service with new plugs etc. Car is now putting out 350bhp and Martin thinks the engine has a bit of a carbon build up.
He's more than happy to clean it out but the costs are obviously going to be increased so he's suggested taking it back and giving it a good thrashing for a few weeks.
Also mentioned some additives I can buy off the shelf to assist with cleaning, will have to search on here for what to buy.
Looking forward to getting it back now!!!
Audi S4 (B9)
Gone:
C63 Coupe (2014)
Audi S4 (B8)
BMW M3 (E90)
Audi RS4 (B7)
BMW M5 (E60)
BMW M3 (E46)
P_G
Post by P_G » Tue Jun 07, 2011 2:07 pm
Wynns DIP3 is the best stuff for cleaning, petrol additive and Intake spray; latter only really to be used pre-oil change / service. I get mine from Andrew Page MotorFactors; if not Wynns Petrol Gold treatment from halfords.
DazN
Post by DazN » Tue Jun 07, 2011 3:58 pm
P_G wrote:Wynns DIP3 is the best stuff for cleaning, petrol additive and Intake spray; latter only really to be used pre-oil change / service. I get mine from Andrew Page MotorFactors; if not Wynns Petrol Gold treatment from halfords.
Thanks!
I have read the intake spray can be done at any time though? I don't want to ruin anything as it's just had service and new plugs and Unit 20, would hate to undo all their good work!!
Audi S4 (B9)
Gone:
C63 Coupe (2014)
Audi S4 (B8)
BMW M3 (E90)
Audi RS4 (B7)
BMW M5 (E60)
BMW M3 (E46)
klauster
Post by klauster » Tue Jun 07, 2011 5:14 pm
Daz-RS4 wrote:Resurrecting this thread because the car's at Unit 20 now.
I take it the power increase was noticed after the full service then like mine?
DazN
Post by DazN » Wed Jun 08, 2011 12:08 pm
I'm working in Germany at the minute so I haven't collect it yet, going tomorrow straight from the airport and then giving it a good thrashing up the motorway :-)
Audi S4 (B9)
Gone:
C63 Coupe (2014)
Audi S4 (B8)
BMW M3 (E90)
Audi RS4 (B7)
BMW M5 (E60)
BMW M3 (E46)
DazN
Post by DazN » Wed Jun 22, 2011 9:51 am
Hi All
So I've had the car back a couple of weeks now and it does feel better, not sure it's any faster but it's a lot more responsive and I'm enjoying it.
The 2nd dyno run after a full service including plugs didn't really show much better results, graph attached with 2 runs overlaid.
I'm wondering if it's worth spending a few hundred and having the engine de-carbon'd? Would I see a noticable improvement or am I just chasing figures...?
Audi S4 (B9)
Gone:
C63 Coupe (2014)
Audi S4 (B8)
BMW M3 (E90)
Audi RS4 (B7)
BMW M5 (E60)
BMW M3 (E46)
ShaneyB
Post by ShaneyB » Wed Jun 22, 2011 11:46 am
I think you'll see a big improvement with manifold polish/port but where do you stop? Manifold polished/ported, remap, filters, cold air feed, change/remove cats, exhaust??
Healthchecks and dyno runs are great but as soon as you see you're not making the power others are from stock a can of financial worms opens.
I had a budget of £1800.00 to get my work done which has now risen to £3k. I'm sure I'll be chuffed to bits with the results but even now I'm trying to work out how I can raise funds for the Milly.
My 2p's worth.
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
P_G
Post by P_G » Wed Jun 22, 2011 12:50 pm
Daz-RS4 wrote:Hi All
Just chasing figures and to be honest, it is not a few hundred, it is several hundred to decoke unless you DIY.
pisquano
Post by pisquano » Wed Jun 22, 2011 1:54 pm
I think MRC asks for a bit north of £1000 to decoke
"you can be my wingman anytime!"
"bullshit...you can be mine!"
CheeRS
pisquano
Post by pisquano » Wed Jun 22, 2011 1:56 pm
Shagga wrote:I think you'll see a big improvement with manifold polish/port but where do you stop? Manifold polished/ported, remap, filters, cold air feed, change/remove cats, exhaust??
My 2p's worth.
frankly if you get something like 50 bhp in one go that's really good and I am pretty sure it WILL be noticeable
very curious to see where you get to Shane
I am a bit dubious about too many modifications, as it could make it hard to sell the car (when and if....) - a lot of people are more willing to buy stock cars (not always for the right reasons but hey), not least as it normally means a higher premium
CheeRS
ShaneyB
Post by ShaneyB » Wed Jun 22, 2011 2:19 pm
pisquano wrote:I think MRC asks for a bit north of £1000 to decoke
Over £700.00 for manifold polish & port in labour alone.
Shane
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Users browsing this forum: No registered users and 259 guests
