RS4 Intercoolers on an S4
Guys,
I have had KO4's etc installed on my S4 and a custom map done. Now I am considering installing some RS4 intercoolers and RS4 air intake on the S4. Would I be able to do this ok and not get a custom map done straight away?
What I am hopeing for is a little extra power maybe but also to keep everything in better working order, ie, cooler with more air.
So if I do the above work, I will be able to quite happly continue motoring along and get a custom map done again a few months down the line to make use of the changes? I am not going to break anything or reduce life spans of any items by doing this?
Cheers,
Rich.
Cheers,
Rich.
Re: RS4 Intercoolers on an S4
You should be fine running the RS4 intercoolers until you get another re-map.
I had RS4 intercoolers fitted to my S4 which had had the KO4 conversion by AmD.
IIRC the ECU wasn't remapped but the car felt smoother. Only trouble was that the dyno plot showed 10BHP less - probably because of the temperature.
It was quite a long job too as they had to squeeze the larger IC's into the space occupied by the smaller S4IC.s and custom make the piping.
Worth doing though.
Worth doing though.
BRETTCOLLINS
- 5th Gear
To much work cutting to make the RS4 intercoolers to an S4, an having a custom set made that are bigger than RS4 but will fit alot easy to the car. will be done this month.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Car is on Lock down
AWE Tuning do some S4 intercoolers which look pretty
good.
good.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
BRETTCOLLINS
- 5th Gear
Yes, But they are in the us and they are on back order, then there is the cost.
thanks anyway.
thanks anyway.
MING BLUE AUDI S4
Car is on Lock down
Car is on Lock down
The RS4 intercoolers will fit an S4 without cutting anything major. You just need to trim the bumper slightly and do some minor work to the ducts. I may be selling some brand new ones soon so let me know if you are interested. If you are running K04's and higher boost than standard, you will see benefits from the intercoolers.
you have pm
APR do a kit to adapt up from the S4 pipework to the RS4's. There are 4 pipes, you will need this as well if you have standard S4 pipework and intercoolers at present.
David
David
Thanks, I will prob get the work done at an 'APR' garage anyway so that should not be a problem.
Users browsing this forum: No registered users and 60 guests
