Battery relocation on rs6
Re: Battery relocation on rs6
Go on rs6.com most of the yanks want the battery in the spare wheel well, i'm sure someone there would love to swap for yours.
Amanda,Amanda,Amanda,roof box...NOOOOOOOOOOOOOOOOO......
RS 6 Avant,
Ebony black mettallic,03 plate,
H&R coilovers,
miltek back boxes,
pirelli p zero's,
H&R coilovers,
miltek back boxes,
pirelli p zero's,
Imola_Sid
thanks for the input everyone.
I'll look into the US spec.
Whats under the rear seats? Possible home?
SOLD - Avus RS6 Avant|KWV3|Hotchkis ARBs|RNSE|HighTech interior|Solar roof|Double glazed|Vreds|Non res Milltek|Phaeton brake ducts
VW T3|Avo 70mm drop|Subaru EJ25 motor|Audi 200 turbo trans|996 brakes|Peloquin LSD|RJES exhaust
Fuel tank.
Amanda's is in the roofbox
bilko1 wrote:Amanda's is in the roofbox
Shuussshhh
950 nm torque!
WAFWOTTBI wrote:Amanda,Amanda,Amanda,roof box...NOOOOOOOOOOOOOOOOO......
Quite agree - the roof box should be LONGER to match the car roof in aesthetics...
C7 A6 allroad 3.0TDi.
Tiguan 2.0TDi R-line
Should be colour coded imhodrybeer wrote:WAFWOTTBI wrote:Amanda,Amanda,Amanda,roof box...NOOOOOOOOOOOOOOOOO......
+1bilko1 wrote: Should be colour coded imho
like ziss:Monaro-Azz wrote: So the RS6's over there have a battery box that mounts to one of the side panels in the boot/cargo bay which houses the battery so they can fit a spare in.
Maybe see if you can find one of those battery boxes on ebay or through a specialist Audi wrecked over there?
Or you may be able to order one directly from Audi here as it's a stock part?
What would be the point, as I understand that you can't fit a 19" RS6 tyre in the spare well, even if the battery is out!?
Present:...
Past:
Past:
why does it need to be a 19inch? These guys clearly have a wheel in there. What about a 17 with a deflated tyre? Then just pump it up when needed?
A 17" rim won't clear the brembo's on the RS6, it clashes with the caliper.
Present:...
Past:
Past:
Not with the right spacer it doesnt.SteveH wrote:A 17" rim won't clear the brembo's on the RS6, it clashes with the caliper.
Users browsing this forum: Majestic-12 [Bot] and 341 guests
