Dear All,
The EPC light came on along with car going into limp home mode; engine switch off/on reset the limp home mode but left the EPC light on. Audi have told me the following fault codes were logged - they have reset and car is running OK with EPC light off. Any advice/suggestions on what would cause the following combo of codes would be much appreciated:
17819/P1411/005137
Secondary Air Injection System; Bank 2: Insufficient Flow
18265/P1857/006231
Load Signal: Error Message from ECU
18619/P2187/008583
Bank 1; System too Lean at Idle
17796/P1388/005000
Control Module Malfunction - DBW Throttle Monitoring
Many thanks
Fault Codes - Advice Please
Re: Fault Codes - Advice Please
secondary air injection system (used to warm cat when cold).
Either pump playing up or hose disconnected. will only ever come on when cold - you can run Vag Com to test the fan - sounds like a little supercharger.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 1650 guests
