Ticking noise when cold
mavada
Post by mavada » Tue May 03, 2011 11:03 am
Hi all,
Ive got a ticking noise this morning with cold engine.
At disappeared when the engine was warm. ive heard it can be the N80, fuel return selonoid etc.
Anyonbe got an idea. i went to a Audi stealer and the mechanic said his son has a s4 with the same ticking (althought he didnt hear it because the engine was warm when i got there, no errors with Vagcom except the 16985 one..) he changed the oil with a more quality one and it was much less. i use 505001 5w30 recommended by Audi (they also did the oilchange) but ive read stories on this forum its better to use 5w40...
Could it be because of the use of 5w30 the oil is more likely to drip of parts when cooling down then 5w40...so it takes longer to get the oil pumped through the engine? it was changed 3000 km ago....
No update/solution on my ecu 16985 problem yet...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
bilko1
Re: Ticking noise when cold
Post by bilko1 » Tue May 03, 2011 12:41 pm
It tells you in the handbook that the engine might rattle / tick when started from cold, it's the hydraulic tappets.
Rupert
Post by Rupert » Tue May 03, 2011 1:00 pm
Half-way down the left hand side of this photo there is a black valve, that could be the cause of the ticking. Touch it you will feel it clicking. It's Normal.
mavada
Post by mavada » Tue May 03, 2011 5:05 pm
But why is it normal if i didnt hear it before...?
Yellow Koni's
Post by bam_bam » Tue May 03, 2011 8:36 pm
mavada wrote:But why is it normal if i didnt hear it before...?
Because you've made it through the RS6 honey-moon period and now you're in the paranoia period. Your ears are now directly attached to your wallet and capable of picking up subsonic noises that usually turn dogs inside out.
micdee
Post by micdee » Wed May 04, 2011 12:34 am
bam_bam wrote:Because you've made it through the RS6 honey-moon period and now you're in the paranoia period. Your ears are now directly attached to your wallet and capable of picking up subsonic noises that usually turn dogs inside out.
:notworthy: So beautifully to the point ...
STOLEN : Das phantom: Ebony Black, RS6+ optic package in- and outside, some sort of ECU remap, sportec exhaust, 275/30 19 with RS6+ rims. --> "GTA is da new name of da game. "
Malcolmx92
Post by Malcolmx92 » Thu May 05, 2011 7:51 pm
Just this weekend gone while topping up the screen wash while the engine was running from cold i also for the first time noticed the ticking sound coming from the black valve so i called out Audi Assistance who advised it was quite normal.He did explain it was something to do with the fuel being sent and recieved...He did explain in some detail as to why it was ticking but it was a bit technical for me...Rest assured quite normal. :D
mavada
Post by mavada » Thu May 05, 2011 8:16 pm
i think the black valve complains about the amount of fuel that passes and probably comes from a Deawoo Matiz... :D
This morning the ticking noise was gone, but im still getting new oil in it, 5w40 instead of 5w30... :audibash:
Thanks for the input Malcolmx. :beerchug:
Yellow Koni's
Post by bam_bam » Thu May 05, 2011 9:13 pm
Nup. I still reckon it's the post RS6 honeymoon period.
Cornishmoocher
Post by Cornishmoocher » Thu May 05, 2011 9:45 pm
it IS the fuel return solenoid......been told already here and elsewhere.
It's all Bollox.
Post by bam_bam » Thu May 05, 2011 10:05 pm
Nup, ya wrong. It's a new condition called RS6 ear.
Cornishmoocher
Post by Cornishmoocher » Thu May 05, 2011 10:21 pm
hehehe fastest money draining substance known to man
It's all Bollox.
Malcolmx92
Post by Malcolmx92 » Thu May 05, 2011 10:59 pm
Time and Money waits for no man...
Especially Applicable to those who own and run a 6 properly...
PHILRS6+
Post by PHILRS6+ » Sat May 14, 2011 5:12 pm
Unfortunatley Lotus Carlton sold today to keep feeding these hungary horses.
Malcolmx92
Post by Malcolmx92 » Tue May 17, 2011 7:00 pm
Was always a childhood dream to own a Lotus Carlton!!!
How did you find ownership PHIL??
Users browsing this forum: No registered users and 312 guests
