Problems found after trip to MRC
Steve_C
Re: Problems found after trip to MRC
Post by Steve_C » Wed May 04, 2011 8:19 am
edge wrote:
Revo wrote:
aka_dk wrote:whats your mileage ?
10hrs at c.£70 an hour is expensive for 40hp esp when the carbon will only come back
After how many miles will this problem happen again ?
Im curious to see what the estimates are here for the return on the Carbon RS4 killer!
It depends on how you drive it IMO.
Gone to the dark side
P_G
Post by P_G » Wed May 04, 2011 8:47 am
As soon as you turn the ignition; it's a by product of FSI. To what degree and physical amount, who knows but it's not linear. Like said a lot is about how the car is driven / frequency / length of use, warm up proceedure, full use of rev range / Italian tune-up etc etc. Go and see how your car fares against DK's and in the meantime try seom Wynns DIP3 petrol addittive to see if it perks the engine up a bit. 10% gain in a 400bhp+ car weighing 1700+kg will probably not amount to much difference on the road as Pad125 and I found.
PJC
Post by PJC » Wed May 04, 2011 8:57 am
P_G wrote:As soon as you turn the ignition; it's a by product of FSI. To what degree and physical amount, who knows but it's not linear. Like said a lot is about how the car is driven / frequency / length of use, warm up proceedure, full use of rev range / Italian tune-up etc etc. Go and see how your car fares against DK's and in the meantime try seom Wynns DIP3 petrol addittive to see if it perks the engine up a bit. 10% gain in a 400bhp+ car weighing 1700+kg will probably not amount to much difference on the road as Pad125 and I found.
Will do thanks.
P_G
Post by P_G » Wed May 04, 2011 9:07 am
I should also say I am not knocking MRC's work and / or diagnosis. If you have the money to do the work and want to spend it then that's your perogative. The reality is there is not long term cure for this and it will return to some extent and with its return would be the perceived lack of power so it is whether you want tp pay for it to be regularly cleaned to keep it in peak condition for that few extra bhp.
My RS is taking a back seat on the daily commute for a more frugal model as of tomorrow so with it being stationary more often I may now take the time to have it opened up and see what the picture is on a 80+k mile RS4 than has never been cleaned for a comparison.
Adam
Post by Adam » Thu May 05, 2011 10:28 am
thinking of getting MRC to do this - so can you confirm the cost is £700, is this including or plus the dreaded 20% VAT?
PJC
Post by PJC » Thu May 05, 2011 2:49 pm
Speak to Doug for the price, that was the figure mentioned to me I don't know if it varies on how bad it is.
edge
Post by edge » Sun May 08, 2011 9:19 pm
Thanks for that, so anyone hot an idea on the optimum warm up steps & driving style to reduce the effects? I know none of this is tested, just curious on what everyone thinks.
I use mine as a daily driver and wait till its warm before giving it some beans. Do like to get it over the 5500k sweet spot, but with full care an attention!
Recon I need to get her on the dynos!
P_G
Post by P_G » Mon May 09, 2011 11:00 am
My own schedule is not to do anything over 3k rpm until it is up to 60 degrees C and nothing over 3.5krpm until up to full temp (94-97 degrees C). Then it's ready for full deployment.
ShaneyB
Post by ShaneyB » Mon May 09, 2011 3:54 pm
I'm getting this done and said I thought the port & polish was a waste of time as it wasn't permanent.
I was told something like this.
'The polish and porting/modified intake is permanent - the clean is good for the car and the porting and modified intake manifold stops the build up being as bad'.
Expensive agreed but surely it can only do the car good?
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
sonny
Post by sonny » Mon May 09, 2011 6:59 pm
Shagga wrote:I'm getting this done and said I thought the port & polish was a waste of time as it wasn't permanent.
Are you having the IM de-vaned so it runs in constant homogeneous operation?
Steve_C
Post by Steve_C » Mon May 09, 2011 7:06 pm
P_G wrote:My own schedule is not to do anything over 3k rpm until it is up to 60 degrees C and nothing over 3.5krpm until up to full temp (94-97 degrees C). Then it's ready for full deployment.
I keep things below 4k and half throttle until until approx 90-95 degrees.....I will then give it the beans until the last couple of miles of the journey when I aim to get the oil temp back down below 100 degrees.
Incidentally, when should the 7k rpm limit go? I've seen mention of 60 degrees (per P_G above) but my temp seems to be more like 69-70 when the rev limiter goes.
edge
Post by edge » Tue May 10, 2011 7:22 am
So nothing over 3.5/4k until the temp is in the 90s from what people are saying?
sonny
Post by sonny » Tue May 10, 2011 7:52 am
edge wrote:So nothing over 3.5/4k until the temp is in the 90s from what people are saying?
That sounds about right, think its good practice.
fyi MRC remap is set to 5K limit until warm up is achieved.
ShaneyB
Post by ShaneyB » Tue May 10, 2011 10:17 am
Are you having the IM de-vaned so it runs in constant homogeneous operation?[/quote]
I'll find out.
Shane
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
edge
Post by edge » Tue May 10, 2011 11:56 am
Drove into work today, kept an eye on rev counts and drove as normal, so recon im good to go.
Plan is a trip to MRC this year, just need to figure out what exactly I want ;)
Users browsing this forum: Google [Bot] and 113 guests
