Hi Chaps can anyone answer the following???
The B7 RS4 V8 flywheel is approx 10mm larger in diameter and has a 10 bolt fixing in the centre.
Is the B7 RS4 gearbox the only quattro manual box that has the larger bell housing to accommodate the larger flywheel?
B7 RS4 Flywheel / Gearbox questions
Yes.
But the RS4 flywheel can be machined down slightly and a spacer plate of 15mm can be used to mount it to an 01E or an 016. Still using the RS4 starter motor, DM flywheel and clutch.
Users browsing this forum: No registered users and 75 guests
