SD card operation
BenWat
SD card operation
Post by BenWat » Tue Apr 26, 2011 10:31 pm
Hi all, hopefully an easy one, have some sd cards, iTunes converted from aac to mp3, and transferred onto sd card.
Problem is I put each album into a file and transfer but the stereo only reads first folder.
Do I have to open one file then each album as a sub file?
I'm just trying to get albums separated out?
Any help gratefully received
Ben
pisquano
Re: SD card operation
Post by pisquano » Wed Apr 27, 2011 10:06 am
I have a folder for each artist, and then sub-folders for each album
works fine - I only have some issues with the shuffle, as it does work, but it only shuffles 2 or 3 songs per folder then moves to the following one, so I found that if you have many albums for the same artist, it kinda sucks
"you can be my wingman anytime!"
"bullshit...you can be mine!"
CheeRS
BenWat
Post by BenWat » Wed Apr 27, 2011 10:21 am
Very odd, I've got maybe 10 folders for 10 different artists, but it'll only open and play the first folder, any other thoughts?
andre3k
Post by andre3k » Wed Apr 27, 2011 10:43 am
I'm not sure I understand your prob correctly; your use of the words file and folder are confusing me.
But, for instance this is how mine is setup & I have no probs:
SD Card >> Artists >> Albums >> Songs
eg.
............>> Michael Jackson >> Thriller >> All Songs
........................................>> Bad >> All Songs
............>> Jon Legend >> Let's Get Lifted >> All Songs
.................................>> Once Again >> All Songs
To move in between Albums when a song is playing & on the CD/TV screen press the Return button once. To move in between Artists press the Return button twice
Pie
Post by Pie » Wed Apr 27, 2011 10:50 am
Are you using an SDHC card or normal (old school) SD Card?
AFAIK, SDHC cards are not compatible.
**Edit**
Theres also a capacity limit, 4GB I think?
3.141
_________________________________
'14 C63 AMG Edition 507
'07 B7 RS4 +Milltek Non-Res, Non-Valved (Sold)
'10 YZF R1 + Akrapovics
pisquano
Post by pisquano » Wed Apr 27, 2011 11:19 am
Pie wrote:Are you using an SDHC card or normal (old school) SD Card?
**Edit**
2GB afaik
CheeRS
Steve_C
Post by Steve_C » Wed Apr 27, 2011 11:19 am
Yes, it has to be SD cards which can go up to 4gb. Although I only ever see 2gb cards for sale.
Gone to the dark side
ShaneyB
Post by ShaneyB » Wed Apr 27, 2011 12:51 pm
Return Button
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
BenWat
Post by BenWat » Wed Apr 27, 2011 1:45 pm
Thanks I'll have another go, just to confirm, it's a 2gb SD card, all music converted to MP3 via noteburner, and music does play, just music in the first of the 10 folders I've opened, the other 9 don't seem to come up at all.
I have created a folder for example U2 and put all the songs by U2 in that, then another folder for Kenny Kravitz, and put all the songs in that. I have 10 seperate folders, but when I access the SD card I can only access the first folder so:
Folder called U2 > all u2 songs
Folder called Lenny >> all Lenny songs
etc
Pretty sure I tried the return button but I will try again
klauster
Post by klauster » Wed Apr 27, 2011 3:11 pm
Steve_C wrote:Yes, it has to be SD cards which can go up to 4gb. Although I only ever see 2gb cards for sale.
I have 4gb sd cards
http://www.amazon.co.uk/Platinum-177106 ... 350&sr=8-3
Steve_C
Post by Steve_C » Wed Apr 27, 2011 3:14 pm
Good find - may have to purchase some of those. :thumbs:
PetrolDave
Post by PetrolDave » Wed Apr 27, 2011 5:11 pm
pisquano wrote:2GB afaik
Not this old cherry again :bash:
Let's spell it out again...
SD vs SDHC or SDXC
The RNS-E will only accept SD cards, not SDHC or SDXC cards.
The maximum capacity of an SD card is 4GB - which the RNS-E WILL happily read.
The "elephant in the room" is that the minimum capacity of SDHC cards is 4GB, and MOST 4GB "SD" cards on sale are NOT SD but SDHC cards, even if advertised as SD cards so you have to check VERY carefully.
No. of files
The RNS-E has a limit of 512 files PLUS folders. So if you have folders per artist and folders per album they come out of the 512 limit.
All files AFTER the 512 limit will be ignored.
MP3 Tag type
The RNS-E cannot accept files with later version of the ID3 tag.
The file breaking this rule AND ALL FILES AFTER will be ignored.
Filenames and path lengths
Old RNS-E software versions wouldn't accept files with special characters in them (like "!"), newer versions don't have this restriction.
The maximum path length (i.e. \\folder\sub-folder\filename.mp3) is 64 characters.
Break either of these rules and the file with the problem AND ALL FILES AFTER will be ignored.
Steve_C
Post by Steve_C » Wed Apr 27, 2011 8:10 pm
Ha ha, Dave! You must've explained this more times than your car gets miles to the gallon!
Worth having it as a sticky?
irvind
Post by irvind » Wed Apr 27, 2011 8:43 pm
BenWat wrote:then another folder for Kenny Kravitz,
Sorry, I know it's just a typo, but I was wondering if Kenny and Lenny are related? :bigblink:
Haha.
PetrolDave
Post by PetrolDave » Thu Apr 28, 2011 2:23 pm
Steve_C wrote:Ha ha, Dave! You must've explained this more times than your car gets miles to the gallon!
If I got £1 for every time I've posted it on an Audi related website I'd have paid cash for an R8 by now :jump_clap:
Users browsing this forum: No registered users and 233 guests
