What product(s) should I use to clean exhaust tips?
As title says my exhausts are looking a little dirty and a simple wipe with an old sponge isn't enough to bring them back to the nice, polished finish.
Any tips? (Excuse the pun)
Nick
Nick
Re: What product(s) should I use to clean exhaust tips?
I use Meguiars "All Metal Polish". Get's them up a treat!
Autosol will also do the trick. Sold in Halfords.
Thanks. Bought Metal Polish from Halfords and they have come up a treat
+1daytonamc wrote:I use Meguiars "All Metal Polish". Get's them up a treat!
Depends how bad they are.... When I bought my RS6 2nd hand I used Astonish on the Milltek tips!!!
Current : 2016 Audi SQ7
| Radical SR3 Supersport
| Ultima Evolution
Good results there Phil.
I'm trying Optimum metal polish at present and it seem to do a better job than Autosol looks shine and reflection wise but Autodsol better on getting rid of initial oxidation so use the latter first and then the former as a top coat.
Optimum brought up all the chrome door furniture on the front door a treat.
+1 to the above. I used Autosol as then initial oxidisation clean, then to maintain the look used Optimum metal Polish to great effect when had the Evo to keep the pipes nice and brite and under the bonnet for all the alumnium and britework.P_G wrote:I'm trying Optimum metal polish at present and it seem to do a better job than Autosol looks shine and reflection wise but Autodsol better on getting rid of initial oxidation so use the latter first and then the former as a top coat.
Currently I am using the Britemax twins - polish and selant, you can see the results in my detai ling threads. I use a MF pad to apply and work in, then a mf to buff off. If need a bit more bite then a bit of wire wool or various grades of wet and dry as required to bring them up nice.
...All in the Detail
a great guide here from Andrew (aka Pomme) over on R32OC.com
http://www.r32oc.com/car-care-detailing ... pomme.html
His Tornado Red 500BHP Turbo 5dr Mk4 R32 (v.rare - only 8 made!!) is spotless
goose
goose
Current:
'08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
'72 Sunburst Yellow VW Karmann Ghia Coupe|1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 interior
Past:
'06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
Past:
Or people could save themselves another wasted hour of their lives,.... rub on sub Autosol (or similar), wait a minute.... then rub off. Job done.
ExactlyTimsterRS4 wrote:Or people could save themselves another wasted hour of their lives,.... rub on sub Autosol (or similar), wait a minute.... then rub off. Job done.
Drive low,park lower
Or you could usse Autosol and then Optimum Metal Polish on top and take two minutes every couple of months instead of having to resort to Autosol for a minute every few weeks.....
Optimum produces a far higher sheen and lustre than Autosol.
I just use alloy wheel cleaner and a scourer or wire woool if they're bad.
Mine were dirty, i used "Autosol" they cleaned up nicely:)
Users browsing this forum: No registered users and 11 guests
