Puff of smoke on startup
Post by Shoppinit » Mon Apr 11, 2011 10:34 am
I noticed this a couple of times recently.
Sometimes when I start the car, I get a puff of gray / black smoke from the exhausts as the engine fires up. I'm not sure if it's both sides or just one.
I have a feeling that it might be an excess of fuel due to me having started the engine just previously to move the car out the garage, but I need to do some more testing.
Anyone have anything similar?
Gravitypilot
Re: Puff of smoke on startup
Post by Gravitypilot » Mon Apr 11, 2011 12:12 pm
i think i do also from cold...
03 Mugello Pearl Avant 32K
MTM Tuned, Vreds, Miltek 520+ :-)
Need any parts? just give me a shout on PM
JCviggen
Post by JCviggen » Mon Apr 11, 2011 12:15 pm
Well if it's not blue but gray and a seriously noticable amount that must mean you get some fuel in the intake during rest. Usually a leaking injector that seeps fuel until the fuel pressure drops (nothing else that can deliver fuel there) . I do not think it is normal, but on the other hand it's nothing to panick about either, it's only a little richer on startup then.
981 Cayman GTS Gray/Orange.
My youtube
posterboyj
Post by posterboyj » Mon Apr 11, 2011 9:04 pm
grey or black indicates over fuelling - blue is burning oil. I would use Vagcom to check the health of the pre & post lambda and block 031 for fuel trims
Cornishmoocher wrote:Buying an RS6 and then worrying about the fuel consumption is a bit like buying a boat and worrying about getting it wet.
drybeer
Post by drybeer » Mon Apr 11, 2011 10:56 pm
I get a similar thing but NOT every cold start. Mostly it's when I've started the car to reverse out of the garage, washed it and then simply put it away again. If the car has had a run then I don't get anything.
Would oil in the cylinder liners not cause a little of this also?
My 911s used to give a puff of smoke also when not started for a few weeks - but I put this down to the flat engine and oil lying in the bores. Don't know if it's at all possible in a V8?
C7 A6 allroad 3.0TDi.
Tiguan 2.0TDi R-line
JCviggen
Post by JCviggen » Tue Apr 12, 2011 8:32 am
posterboyj wrote:I would use vagcom to check the health of the pre & post lambda and block 031 for fuel trims
I do not suspect he'd find anything meaningful there. On startup neither lambda is active because they need to warm up first. Startup is a pre-determined amount of fuel that I do believe has a correction factor based on what the ECU sees in normal closed loop running but then it would have to run like crap which is obviously not the case.
It has to be some fuel that seeps into the intake after the engine has been turned off. If it only does this after standing still a good period of time (so not when restarting it right away) then you've found the most likely problem.
My youtube
Post by Shoppinit » Wed Feb 29, 2012 10:19 am
Bumping this back up.
I reckon my startup puffs are oil burning. They are definitely blueish / white. Only last for about a second.
Same amount of smoke from both sides.
Not many places where oil could get in to the cylinders in such small quantities. I'm thinking valve stem seals.
Anyone have any ideas?
mavada
Post by mavada » Wed Feb 29, 2012 10:33 am
On cold engine starts, especially, the ECU will momentarily run a rich mixture to get ignition going, then thin it back to normal once the O2 sensor can get an accurate reading. The puff of 'smoke' probably has a sweet smell and would contain a small amount of poorly combusted fuel, some uncatalyzed exhaust, and likely a bit of condensation.
You see the same thing with worn or damaged valve guide seals. The way to tell the difference is to let the car sit overnight, then inspect the inside of the cylinders (through the spark plug hole) using a bore-scope. If there's oil, it's valve seals. If it's clean, it's turbo seals.
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Post by Shoppinit » Wed Feb 29, 2012 10:46 am
Thanks for that copy / paste from the saab forum. ;)
As I said above, the smoke is blueish, so it's not overrich mixture. Don't think it's the turbo seals because of the distance from the turbos to the inlet and the fact that the smoke is only for a very brief duration. I discounted oil accumulation in the intercoolers for the same reason, although I cuold be wrong about that; I might drain them to see. Because they are not made of swiss cheese like the OE ones then the oil has nowhere to escape to.
I don't think I'm going to worry about it until it gets worse. If it does. Was just wondering if other's did it and I find it odd that I have *never* heard of a problem with valve stem seals on the RS6.
mavada
Post by mavada » Wed Feb 29, 2012 10:57 am
yeah, you came across that post too. I thought it might have a explanation to your possible trouble...
Yellow Koni's
Post by Shoppinit » Wed Feb 29, 2012 10:58 am
It's not a bad explanation. I just don't think that you would see such small quantities of oil using an endoscope. Not that I have one, and I certainly can't be bothered to go to the faff of pulling plugs out.
el_ringo
Post by el_ringo » Wed Feb 29, 2012 4:16 pm
Im sure I get a tad of blue when I start it cold after being sat a few days. It is not nearly as much as the wifes old boxster used to chuck out. Ill go start it now and look again....
Daytona Grey (C5) RS6 saloon, but just a little better...
**** SOLD!!! :( ****
KW V3 suspension
390mm C6 Brakes
Hotchkis ARBs
Viper Tuning (537bhp 604lbft)
Unit 20 TCU remap
Milltek non-res exhaust and downpipes
100 cell sport cats
Aero wipers
Winter wheels
Wagner intercoolers
LED interior lights
Tesla Model S 85D
All the options with the exception of stupid air suspension
Tesla Model X 60D
Silly doors and all!
el_ringo
Post by el_ringo » Wed Feb 29, 2012 4:21 pm
None this time, I even started it twice to test moving it out. I will have to see when it does it again.
KW V3 suspension
390mm C6 Brakes
Hotchkis ARBs
Unit 20 TCU remap
100 cell sport cats
Aero wipers
Winter wheels
Wagner intercoolers
LED interior lights
Tesla Model S 85D
Tesla Model X 60D
vikingrs6
Post by vikingrs6 » Wed Feb 29, 2012 6:22 pm
Shoppinit wrote:Bumping this back up.
Hi Shoppinit, I had a similar issue.. check this out http://forum.rs246.com/viewtopic.php?f=2&t=82851 and http://www.rs6.com/showthread.php/20472 ... highlight=
RS6 C6 - Stock atm but will be getting an MRC Stage 2 shortly
RS6 C5 - H&R'd and MRC'd Happy Days!..
Post by Shoppinit » Wed Feb 29, 2012 6:38 pm
I remember those posts. How was the oil getting into the cylinders? Throught the sparkplugs? How come you had smoke coming from both sides though, but managed to fix it with one rocker cover gasket?
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 245 guests
