Coil pack crisis
Re: Coil pack crisis
I have a rs4 06, I will be calling audi about this on monday, I have 109 days before next services or should i just wait untill then???
do it now
- PetrolDave
+1pad125 wrote:do it now
They can do it while you wait, Southampton Audi changed all 8 of mine while I waited and it only took just over an hour.
- Steve_C
- Top Gear
Yes, take it in now (assuming they have replacements in stock). Its not guaranteed that yours will need changing though.jasonpaul wrote:I have a rs4 06, I will be calling audi about this on monday, I have 109 days before next services or should i just wait untill then???
Gone to the dark side
Hi all just phoned up poole Audi and booked it in all the coil packs will be change plus a oil pipe as well.
Thank for the information
Had all mine replaced by Camberley Audi under recall.
Can't feel any difference whatsoever nor did I have any issues before. Just my luck the new ones will not be as reliable as the old
RS4 (06) saloon, phantom, satnav+, adaptive lights.
Audi TT MkII Coupe 2.0 TFSI
E36 BMW 328i Coupe (great car)
- PetrolDave
+1zorbs wrote:Can't feel any difference whatsoever nor did I have any issues before. Just my luck the new ones will not be as reliable as the old
Never had any coil packs changed before in 11 years of Audi ownership, and never had any problems - so I've got my fingers crossed that a problem hasn't been created by changing them...
+3
Mine have just been changed as part of my service schedule today; they reckon it is a different manufacturer for the modified packs.
- PetrolDave
Be afraid... changing manufacturer could be good, or it could be bad.P_G wrote:they reckon it is a different manufacturer for the modified packs.
Share the fear Dave, yours may get changed next service whether you wanted it or not which is what I had.
- PetrolDave
Read my earlier post... all 8 of mine have already been changed by Southampton Audi!P_G wrote:Share the fear Dave, yours may get changed next service whether you wanted it or not which is what I had.
In 11 years of Audi ownership I've never had a coilpack fail so I was nervous about getting them changed, and hearing that the new ones are from a different manufacturer has just added to my nervousness - I'm a great believer in "if it ain't broke don't fix it".
Had all 8 changed today at Maidstone Audi, fingers crossed......
All has been done at Poole Audi in about 2 hours, nice coffee as well !!!!!
Just had an oil service and they also changed the coil packs it took about 2hrs. I also have an issue with slight corrosion on the black panel that the mirror is attached too and the bottom of the door plastic panel has moved out slightly. Await too hear the outcome
