Vibration with hubcentric
s3shane
Re: Vibration with hubcentric
Post by s3shane » Tue Mar 29, 2011 7:40 pm
d10uug wrote:I have just fitted some spacers to mine and the 10mm ones had the collar for the wheel to locate but the 8mm for the front didnt, both sets by h&r and all was fine till I did 60mph and it felt like the front wheels were completly out of balance with the 8mms on. I spoke to DPM and they changed the 8s for 10s and it sorted the problem straight away.
Dougie
This is exactly my problem, and I also got mine from dpm. Are 10mm too much on the front?
d10uug
Post by d10uug » Tue Mar 29, 2011 9:03 pm
Ive had no probs since I put the 10s on. I dont know how you could use the others as when I fitted them I tightened the wheel nuts a little each time to aline the wheel but it made no differance at all. So fook knows how they could be used .
Dougie
s3shane
Post by s3shane » Wed Mar 30, 2011 8:15 am
They went on ok and the wheel nuts tightened up fine actually the only trouble is vibration
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Wed Mar 30, 2011 10:23 pm
We stock both 8's and 10's with longer bolts. Both sizes hub centric, and both 150mm face type.
Correct spacers for the B7 unlike other suppliers!
Virdee Autos ~ 07950-526592
ArthurPE
Post by ArthurPE » Wed Mar 30, 2011 11:35 pm
Virdee Autos wrote:We stock both 8's and 10's with longer bolts. Both sizes hub centric, and both 150mm face type.
Shane, get a set of these 8mm x 150 for the front, they will bolt right on, no wobble
