RS6 MISFIRING ANY IDEA'S OFF CAUSE'S???????????
RS6_2011
Post by RS6_2011 » Fri Mar 18, 2011 8:54 pm
hey my car is misfiring like mad any idea's ive tried so many things any idea's?????????????
scooby-tc
Re: RS6 MISFIRING ANY IDEA'S OFF CAUSE'S???????????
Post by scooby-tc » Fri Mar 18, 2011 9:20 pm
Vagcom is your friend
HTH
2003 RS6 Avant (NOW SOLD)
Post by bam_bam » Fri Mar 18, 2011 9:24 pm
Coilpacks?
Post by HYFR » Fri Mar 18, 2011 9:25 pm
is the RS 6 covered by the current coil pack campaign ?
Post by chunky79 » Fri Mar 18, 2011 9:34 pm
RS6_2011 wrote:hey my car is misfiring like mad any idea's ive tried so many things any idea's?????????????
what have you tried so far?
Post by bam_bam » Fri Mar 18, 2011 10:14 pm
Q: what have you tried so far?
A: Putting loads of question marks in the title...
VAGCOM is your friend. Post your location and maybe someone can pop along to help.
RS6_2011
Post by RS6_2011 » Sat Mar 19, 2011 3:59 am
when i drive it to 2000rm the car misfire's and stutters shaking the whole car loosing power no throttle to it doesnt go over 30 to 40mph its gets really bad and engine management light flashes on and off and then stays on i did a diagnostic it showed lamber sensor and misfire cylinder detected so i changed the sensors and drove it and kept doin it again same ting misfiring and stuttering so then i tried diagnostic and it showed all the cylinders misfire detected sometimes 1/5/7 cylinder did it then 8/6/3/2 cylinder did it so i thought it would possibly be the spark plugs so i bought the NGK PFR70 plantinum the whole 8 and replaced them with the old one's deleted the code's and tryed the car again it still misfired showing no faults but on live data diagnostic showed same thing misfire cylinder detected so i thought it must be the coil pack's so i bought brand new 8 coil packs 06b 905 115 e part number and replaced them with the old one's and tried car it still misfires doin same thing showing fault code misfire cylinder detected any other idea's wat can cause this ive been told it can be a ripped pipe some where??????????????????
Post by chunky79 » Sat Mar 19, 2011 7:06 am
F*ck me that was hard to read. Are you in the uk? If so where, cause as stated above someone might be able to scan it for you.
Could be a bad loom conection?
P.s , whats with all the question marks. ????????????????????
Just one other thing, look to the left of your ??????????????????????????? button and you will find 2 little friends ................. ,,,,,,,,,,,,,,,,,,,,
RS6Steve
Post by RS6Steve » Sat Mar 19, 2011 8:55 am
I'm going loom for the fault. Get elsawin of eBay and get the wiring flow chart, pretty easy to fault find with this.
Steve
RS6 gone, R32 gone, M3 gone, Porsche Cayenne Turbo gone, Boring A6 saloon gone, Boring A6 Avant going in 5 weeks :D . Maybe RS5 or S5 Hatchback to come...
mavada
Post by mavada » Sat Mar 19, 2011 9:21 am
Hi Steve,
I can get you the wiring flow chart. ive got elsawin, only its in dutch...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Post by Shoppinit » Sat Mar 19, 2011 10:33 am
First thing to check are the little vacuum pipes. Prone to deterioration. Could be MAFs or lambda sensors. Since this is showing on the diags then it's almost certainly one of those 2. Hopefully for you it'll be the pipes or MAFs.
Don't forget to check the master cylinder vac pipe, too.
Post by bam_bam » Sat Mar 19, 2011 10:58 am
chunky79 wrote:F*ck me that was hard to read. Are you in the uk? If so where, cause as stated above someone might be able to scan it for you.
I know. I read that at 3am and it hurt my frontal lobe, a lot.
"Say 'ello to my liddle friends".
I'd like to start a book on vac leads, anyone?
Post by Shoppinit » Sat Mar 19, 2011 11:00 am
Gimme some action on MAFs.
RS6_2011
Post by RS6_2011 » Sat Mar 19, 2011 1:48 pm
there's nothing showing on the maf side no fault code's or any thing just cylinder misfire detected and how do i know it might be the loom?
bilko1
Post by bilko1 » Sat Mar 19, 2011 10:01 pm
RS6_2011 wrote:there's nothing showing on the maf side no fault code's or any thing just cylinder misfire detected and how do i know it might be the loom?
MAF sensors rarely show up as a fault code you need to log the data from them.
Users browsing this forum: No registered users and 113 guests
