REAR RS4 B7 Brakes on RS4 B5
so i tried fixing the rs4 B7 rear brakes on my B5 rs4 and i got a problem. The bolts that supposed to attach calipers to the car from B5 are too small for B7 kit. The B7 kit came without those bolts. Below are the part numbers of the calipers that I have:
8E0615423K CALIPER 1
8E0615424K CALIPER 1
8E0615425K CALIPER 2
I have checked on ETKA and i found this part number N 910 464 01 BOLTS 4 PCS. The problem is, it is unclear if these are the bolts that I need.
Can anyone confirm if these is the correct part number for those damn bolts? Please help...
Many thanks
Many thanks
jimbo1234567
- 5th Gear
theres 3 different ways to mount the b7 brakes on the rs4.
665 bhp + 586 lbft...
Can you not take the original B5 bolt and the B7 caliper carrier to a hardware shop and ask for a bolt the length of the B5 bolt but large enough to fit the thread in the B7 carrier? Make sure you get it in the hardest type available though. The above way you will have to redrill the upright.
Also search RSmonkey's posts as i am sure he had his done at MRC without the redrilling.
jimbo1234567
- 5th Gear
1.. scallop the b5 hub so you can get in to drill the upright squarely and drill out to take the b7 bolt but be aware the disc will need turning down approx 5mm.
2... use a bolt the same size as the b5 but slightly longer so it goes straight through the b7 carrier and can get a good fat washer and bolt on the other side. this is the mrc method and allows you to pull the carrier out while tightening the bolts that hold it. no disc mods needed here but still not quite there.
3.. same as no 2 but you elongate the holes in the carriers to let it come further out still then the pads will sweep the center of the disc and you will get an even lip on the inner and outer edge of the disc which is what you want.
Many Thanks for the help...I am still waiting for the bolts so once i get them I will try to fix them.jimbo1234567 wrote:1.. scallop the b5 hub so you can get in to drill the upright squarely and drill out to take the b7 bolt but be aware the disc will need turning down approx 5mm.
chiefmechanic
Re: REAR RS4 B7 Brakes on RS4 B5
Do i still need to skim the disc and elongate the bolt holes if i use a b7 disc. Brian
Users browsing this forum: No registered users and 83 guests
