How to remove the silver trim on the rear bumper?
Grazer_skredge
Post by Grazer_skredge » Wed Mar 09, 2011 8:19 pm
Hi all
the silver trim which sits on the top of the rear bumper is pretty grubby, and really lets the rest of my otherwise immaculate sprint blue RS4 down.
Have tried everything on it to clean it but still grubby :(
So, going to remove it and machine polish it, if that fails respray it
Does anyone know a) how to remove the silver trim and b) colour code?
thanks
GS
StuBee
Re: How to remove the silver trim on the rear bumper?
Post by StuBee » Wed Mar 09, 2011 8:23 pm
i got mine vinyl wraped. Wasnt too expensive and looks good too. Was getting the trim round my windows done too so it all matches :D
Grazer_skredge
Post by Grazer_skredge » Wed Mar 09, 2011 9:48 pm
yeah, I did consider the vinyl wrap, but decided to keep it original.
ShouldveBeenAGerman
Post by ShouldveBeenAGerman » Wed Mar 09, 2011 11:10 pm
let me know how you get on with cleaning it up, I'm in the same position. Mint car apart from the damm silver trim. Will get it wrapped if there's no solution
Grazer_skredge
Post by Grazer_skredge » Wed Mar 09, 2011 11:27 pm
sure - I'll have it off the car and machine polished up by end of play tomorrow - will post up some pics when done
steveyb
Post by steveyb » Wed Mar 09, 2011 11:54 pm
Have a word with your local dealer, I had mine changed (and front grille) for a contribution of just 25% what normally would be charged due to goodwill gesture. Car is less than 5 years old and trim was badly corroded / oxidised, it really did let it down - looks great now though.
StuBee
Post by StuBee » Thu Mar 10, 2011 1:17 am
if u are machine polishing be a bit careful i tried megs metal cleaner, stripped right back to the shiny metal underneath!
Grazer_skredge
Post by Grazer_skredge » Thu Mar 10, 2011 7:37 pm
well we managed to carefully remove the trim then tried machine polishing it with a Megiuiars oribital polisher - cleaned it up a bit, but not enough.
So, rubbed it back with some wet and dry and coated it in 3 layers of primers followed by 3 layers of Audi Silver paint from Halfords. Looking much better now. The match is almost perfect to the wing mirrors
Left it to dry overnight before we reinstall in the morn. Will post some pics up when done, then will probably do the front grill surround
GS
RS6chris!
Post by RS6chris! » Thu Mar 10, 2011 8:45 pm
How did you remove it?
I got mine changed under warranty..only for road salt to create a bubbling effect!!!
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
Grazer_skredge
Post by Grazer_skredge » Tue Mar 15, 2011 10:57 pm
Hi
Ok, fairly easy to remove, just carefully slide a flat blade underneath to push the clip out, it then slides backwards away from bumper.
Havent got any pics of it before, but it was dire, covered in muck and brown tarnish that just wouldnt polish out
So, removed, rubbed down with wet n dry, 3 coats of primer, then 4 coats of rattle can from Halfords "Audi Silver"
Very pleased with the results :jump_clap: Might do the front grille trim now
Heres a photo, not great as its taken on my iphone....
ShouldveBeenAGerman
Post by ShouldveBeenAGerman » Tue Mar 15, 2011 11:08 pm
Great result!
andymc
Post by andymc » Wed Mar 16, 2011 1:37 am
Hmm - interesting thread.
Mine looks ok but just doesn't fit ok. Keeps popping out on the left hand side after a few boot lid openings.... very annoying. I guess I need to attempt to remove, clean and check all the connectors are solid.
thanks for the tip about 'audi silver' from Hal-frauds .... need to get some of that as I have a few stone chips on the mirrors which need doing :)
Post by Ian_C » Wed Mar 16, 2011 2:25 am
Got this trim replaced on mine before I collected as part of the deal. Prep sheet says £74.17. HTH
Ian
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 183 guests
