roof aerial
- Gravitypilot
roof aerial
lame subject! but roof aerial was snapped when i check it! i wandered why my radio was pants signal...
any recommendations? is it best to buy gen from audi?
03 Mugello Pearl Avant 32K
MTM Tuned, Vreds, Miltek 520+
Need any parts? just give me a shout on PM
Re: roof aerial
Same is happening to me - is it ok to buy one of the stumpy aerials from ebay, or must it be an oem Audi one?
Mart.
Mart.
C6 RS6 Plus with a few sensible mods...
- Gravitypilot
Re: roof aerial
im thinking oem, if it does anything todo with the gps which i think it does.. hopefully an audi nut will advise
maybe bruno will know
- Gravitypilot
Re: roof aerial
mart did you say you were going for a different hardcore coil over set?
do you have a link? im still deciding what todo with mine.
Re: roof aerial
if the base is still intact you can use any aerial as its only a screw in jobby,if you need the whole lot then OEM will be the answer
2003 RS6 Avant (NOW SOLD)
Re: roof aerial
Bought mine on eBay for fifteen quid make sure it's a Hirschman
Re: roof aerial
Going for the Ohlins Statis setup. Much more driver focused and available with a range of spring options. As they have larger internal resevoirs, it means you can run harder springs (improving the handling) whilst still being plush. Ask Doug from MRC to take you out in his S4 which has Ohlins, it's amazing. Very firm, yet still really plush - not harsh at all.Gravitypilot wrote:mart did you say you were going for a different hardcore coil over set?
http://shop.achtuning.com/STaSIS-Motors ... 5-RS6.aspx
They are $3500 though, so you get what you pay for...
Mart.
- Gravitypilot
Re: roof aerial
yes mart i might just do that..
are you going to be tracking your car alot?
they do look good... when are you having yours installed?
the trouble ive got is im 3 hours from mrc and qst!
Re: roof aerial
I fitted the RS6 Saloon aerial to my plus, very nice and works 100%
I don't have a picture to hand, but Unit 20 supplied it.
Current : 2016 Audi SQ7
| Radical SR3 Supersport
| Ultima Evolution
Coilover kit
If I'd have known about those before getting the PSS9s I'd have grabbed them. How long have they been on the market? Where do the reservoirs install to and which srping rates have you been advised to fit?Ceveman73 wrote:Going for the Ohlins Statis setup. Much more driver focused and available with a range of spring options. As they have larger internal resevoirs, it means you can run harder springs (improving the handling) whilst still being plush. Ask Doug from MRC to take you out in his S4 which has Ohlins, it's amazing. Very firm, yet still really plush - not harsh at all.Gravitypilot wrote:mart did you say you were going for a different hardcore coil over set?
Mart.
Re: roof aerial
They look the dogs. I wonder what the height adjustment range is. I don't like the 'slammed' look and the PSS9 allow me (just about) to have stock height.
Re: roof aerial
Gravy,
I got mine of ebay for £5.00 and its great..It a compact silver ariel that matches the colour of the roof railings...Soooo much better than the original!
Ross
Ross
Re: roof aerial
Does anyone have any ebay examples of aerials that would be compatible?
Cheers,
Mart.
Cheers,
Mart.
Re: roof aerial
Caveman,
I will try and find the one i purchased tonight (cant acecss fleabay at work) and will send you the link..It doesnt need to be an Audi one just one that compatible with the scew in to the existing hole etc (should say which cars it ok for etc)
From memory, i put in AUDI RS6 Accessories in ebay link
cheers
Ros
cheers
Ros
MartWilliams
Re: roof aerial
If you're buying just the screw in bee-sting aerial make sure you get the one with 6mm male thread not 5mm which is for non sat nav audi cars - apparently
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 254 guests
