anyone done this is there a paint and sticker kit i can buy ? from anywhere ?
my calipers are staring to loose there bright red look. starting to fade.
[img]images/graemlins/thumbs.gif[/img]
brake caliper painting ?
Davidp20v
Rs2. Polar Silver. Was Standard 315 bhp. now with de-cats, cone filter, forge diverter valve. samcos next, then chip
Re: brake caliper painting ?
i have put this in the wrong forum page [img]images/graemlins/062802beat_prv.gif[/img]
any moderator please put it in the rs2 section ....... doh !
Davidp20v
I used some of this recently - See Brake caliper paint. Worked really well, and left a pretty good finish. It is a paint on solution, maybe a spray would leave a better finish.
If you do get it, then I recommend that you just mix as much as you need.
Not sure this is in the wrong section - Not RS2 specific. Still want it moving?
Current : 2016 Audi SQ7
| Radical SR3 Supersport
| Ultima Evolution
I've used Foliatec (?). As Phil says you can mix just a small amout, I used a marked up syringe ( always have a few lying around [img]images/graemlins/wink.gif[/img]) and it is then easy to keep the proportions correct ... really messy when it doesn't set [img]images/graemlins/blush.gif[/img]
ChrisG
