I can close all the windows by holding down the lock button for the duration on my keyfob but I've heard there's a setting in VAG-COM that allows the function with a short press.
Does anyone know if that's true?
Total Closure?
- cobraBLACK
Total Closure?
Audi S4 Avant (B6, 2004) in Goodwood Green.
RE: Total Closure?
Not as far as I know... It's just an on/off selection. I can't see any codes within VAG COM that change the press duration.
See here:
http://wiki.ross-tech.com/wiki/index.ph ... ort_System
See here:
| '04 S4 Avant (B6) | NOW SOLD
- cobraBLACK
RE: Total Closure?
Maybe it was a newer model or something.
I know on newer Audis with MMI, electric folding mirrors can be set to (un)fold when (un)locking the car.
RE: Total Closure?
Ah ok. That's probably what it is. Although there's a chance that the functionality exists somewhere buried in the coding, it's just not covered (that I've seen) on the Ross Tech wiki, or on openobd (http://en.openobd.org/audi.htm).
Re: Total Closure?
Would this cover it?
http://www.kufatec.de/shop/product_info ... A4-8H.html
Re: Total Closure?
sorry to hijack your thread but is it right that if you hold the lock button down it should close all the windows? Mine doesnt.... it this likely to not be turned on as a feature? Thanks for any help!
- cobraBLACK
Re: Total Closure?
It's more of a reverse hijack (a rejack?) since that was what it was about originally.jimmywar wrote:sorry to hijack your thread but is it right that if you hold the lock button down it should close all the windows? Mine doesnt.... it this likely to not be turned on as a feature? Thanks for any help!
Yes you should be able to. On that Ross-Tech wiki it sounds like it can be enabled by VAG-COM.
