Coil pack crisis
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Coil pack crisis
Had the coil serial numbers checked during a service yesterday. Apparently they aren't due to be changed under the current recall but the service dept told me that they expect the recall to be rolled (around March time) out to all include my RS4 once more coil packs are available.
They said the reason mine isn't currently included is due to low stock numbers of coils and once Audi get more in stock my coils will be replaced. ie, To avoild a massive demand for coil packs they are rolling the recall out step by step
To me this soulds doubtful but we will see!
B7 RS4
Mi16'd 205 1.9 Gti
1999 Yamaha R6
White Transit
B7 RS4
Mi16'd 205 1.9 Gti
1999 Yamaha R6
White Transit
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Coil pack cr
Thats is a very detailed reply, Cant get better than that!MSLRS4 wrote:Mentioned this to the dealer and his reply was:
Hi Mark,
I have already checked your chassis against the database and it picked your chassis number out as one of the vehicles which is going to be given uprated/new coil packs.
You should receive a letter from Bianca stating the recall, and we’ll get your car in as soon as the coils arrive.
The way this recall works is that every car between certain dates, that is on the list should be brought in. We will have the correct spec coils in for it. However, what will happen will first of all be a check. For example, Audi state that if coils:
Abc123 or
Abc234 or
Abc345
…are in your vehicle they should not be replaced, but if there is any other spec coils, they should be replaced with the latest coil which could be:
Abc123……..which would be the ones we would have ordered in for you.
I hope this gives you an idea into what is going to happen.
xxxx xxxxx
Service Advisor
Salisbury Audi
Hope this helps...Mark
- Steve_C
- Top Gear
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Coil pac
Had mine done today. It is known as the 28E9 workshop action. I waited for the work to be done and when it took slightly longer than the quoted hour they apologised saying they didn't realise there would be 8 to change and that they would be hot!!
Still I've now got 8 new coilpacks FOC
Gone to the dark side
Had mine done yesterday. I have the tech document they issue to the dealer, I'll scan it and post it up tomorrow
RS246 Rules!
Phoned the local dealer, said the magic campaign number, car booked in for 3 weeks hence - due to coil packs on back order. Car registered Oct 06, well out of Audi warranty, no questions asked.
Wonder if this will cure the epc light/ missfire when cold?
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Coil
Rang up yesterday after reading this thread, also booked in for three weeks time and also car registered October 06.
Daytona Avant - Optics - Titanium pack - MRC 464.6ps 513Nm - H&R ARBs + Springs - Apikol Diff mount - 034 Tranny mount - JHM Shifter
I wasn't joking, they didn't know.............RS246 Rulespad125 wrote:Mines in tomorrow, I mentioned it to them and they 'thanked' me for telling them something they hadn't been told!!!! They said they would me for technical help in the future, I directed them to RS246 obviously
neckarsulm
Mine apparently needs to go in for the workshop action
I have asked for the part numbers that need replacing but I suspect they want you in so they can cross you off the list even if you don't need any new parts and I bet they get paid by Audi for just checking.
I have a suspicion there is more to this than misfires, more like just 'fires'!
BTW an 07 reg didn't need the check
neckarsulm
Top response from James at Halesowen Audi as always.
Happy for us to check them ourselves;
"If you would like to check the following part numbers do not need replacing 07K 905 715 F, 07K 905 715 D and 06F 905 115 F"
I'll try and up load the document
File too big, 3.4mb
Basically, it says everything thats been said above with more detail on all the other cars affected. Gives part numbers to check for
Engine code BNS
If the following part numbers are fitted then all OK
07K 905 715F
07K 905 715D
06F 905 115F
If not then they should be replaced with 07K 905 715F
File too big, 3.4mb
Engine code BNS
07K 905 715F
07K 905 715D
06F 905 115F
neckarsulm
just realised you have to take the plugs off the coils to read the PN so 80% of a plug change!
Users browsing this forum: No registered users and 215 guests
