RS4 engine light on with no performance drop
2.7 V6 30v biturbo - 380 bhp
Matt@Reflex
Post by Matt@Reflex » Sun Feb 13, 2011 12:19 pm
Hi Guys.
I am having a little problem with my car.
Some of you may know it (this one)
http://www.rs246.com/index.php?na...wto ... highlight=
Anyway The engine light has started coming on and staying on until i clear it and then it comes back on after a while normally when i'm driving economically (if there is such a thing )
The car still goes like stink and has never dropped to limp mode.
It has Miltek DP's and pipe
Here is the Vag-com log before clearing it.
Am i right in thinking that it is running rich because of the REVO map?
SomSaturday,12,February,2011,09:12:11:60309
VCDS Version: Release 10.6.3
Data version: 20101206
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
VIN: WUAZZZ8DZ1N903657
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 8D0 907 551 K
Component: 2.7l V6/5VT G 0001
Coding: 10711
Shop #: WSC 13620
VCID: 326001B8D4A9
WUAZZZ8DZ1N903657 AUZ7Z0Y1731978
2 Faults Found:
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-00 - -
17547 - Fuel Trim: Bank 2 (Add): System too Rich
P1139 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04395
Shop #: WSC 02325
VCID: 356A3AA425C7
No fault code found.
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00061
Shop #: WSC 00661
VCID: 2D5A12C4CD97
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 J
Component: Airbag Front+Seite 1001
Coding: 01106
Shop #: WSC 02314
VCID: 3D7A22841DF7
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 981 X
Component: B5-KOMBIINSTR. VDO D13
Coding: 00464
Shop #: WSC 00661
VCID: 41825E74610F
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 15210
Shop #: WSC 63351
VCID: 2F6608CCC79B
1 Fault Found:
00955 - Key 1
09-00 - Adaptation Limit Surpassed
Address 37: Navigation Labels: Redir Fail!
Part No: 4B0 035 192 F
Component: Navigation BNO 0001
VCID: 2044FBF08A45
2 Faults Found:
00854 - Radio Display Output in dash Panel insert
49-00 - No Communications
65535 - Internal Control Module Memory Error
00-00 - -
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00102
Shop #: WSC 00759
VCID: E0C43BF04AC5
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 63351
VCID: E5CA2AE455E7
Address 56: Radio Labels: Redir Fail!
Component: Radio BNO 0001
Coding: 00207
Shop #: WSC 00586
VCID: 2044FBF08A45
3 Faults Found:
00852 - Loudspeaker(s); Front
36-00 - Open Circuit
00-00 - -
End ---------------------------------------------------------------------
lengster1
RE: RS4 engine light on with no performance drop
Post by lengster1 » Sun Feb 13, 2011 5:28 pm
Hmmm linky no workie,is it by chance my old beast?
lengster1
Post by lengster1 » Sun Feb 13, 2011 5:32 pm
I never got that code while i had it if it is indeed my old beast,maf? maybe? What settings do you run with the sps high boost is hard on the turbos and for special occasions and good fuel only,even so never got that code when lambdas went and egt sensors
Matt@Reflex
Re: RE: RS4 engine light on with no performance drop
Post by Matt@Reflex » Sun Feb 13, 2011 5:47 pm
lengster1 wrote:I never got that code while i had it if it is indeed my old beast,maf? maybe? What settings do you run with the sps high boost is hard on the turbos and for special occasions and good fuel only,even so never got that code when lambdas went and egt sensors
Hi ya,
Yes indeed it is your wonderfull machine.
http://www.rs246.com/index.php?name=PNp ... highlight=
I have never altered the sps. It is on 3 - 5 low boost and i have only ever ran it on optimax since day one.
Its plenty quick enough at that setting :D
Its puzzling me and i dont really want to buy a new MAF if its not going to fix it.
So are you saying that it should not be saying that its running rich and that i should start investigating that.
Thanks for your help.
lengster1
RE: Re: RE: RS4 engine light on with no performance drop
Post by lengster1 » Sun Feb 13, 2011 7:31 pm
Good to see your keeping her tip top,i would have it looked into it never came up up with that code in the 4+ years i had her so yes i think something needs looking at.Good to see you on here and the pics of it look fab
Matt@Reflex
Re: RE: Re: RE: RS4 engine light on with no performance drop
Post by Matt@Reflex » Sun Feb 13, 2011 8:36 pm
lengster1 wrote:Good to see your keeping her tip top,i would have it looked into it never came up up with that code in the 4+ years i had her so yes i think something needs looking at.Good to see you on here and the pics of it look fab
I'm being told to pressure test the intake system.
Its just weird that the performance is still there.
Its now on 75000miles so still nice and low :wink:
I need to get some nice recent photos on here even though nothing has changed 8)
Users browsing this forum: No registered users and 120 guests
