shredded tyres - the last straw!
Daveperc
Post by Daveperc » Tue Feb 08, 2011 9:14 am
Unless I'm mistaken however, the relative position of the wheel/tyre to knobbly is fixed and independent of the other suspension components/setup.
Correct
Dave
monoi
Post by monoi » Tue Feb 08, 2011 10:20 am
Daveperc wrote:
Extremely good point Monoi, the tyre wall should only undergo deformation when entering and exiting the contact footprint. The infamous knobbly bit is at the furthest point from the footprint, ergo, no tyre deformation?!?!
Sorry guys, but not correct. Think of the tyre and wheel as two concentric cylinders. The lateral force exerted by the road to change the direction of the car is applied to the tyre tread by the road. To transfer the shear force to the wheel (and car) the whole tyre tread is displaced laterally, deforming both tyre walls - the air pressure, and the deformed shape excert the force which is principally transmitted by changes in tension in the fibres in the tyre.
I'm not a tyre engineer, but I am a Chartered MechE .
Dave
Now that you explain it, it does make sense. and I stand corrected. Thinking aout it, I remember some ultra slow mo pictures of a f1 car hitting a kerb and the whole tyre was wobbling.
So tyre pressures are important!
Digger
Post by Digger » Tue Feb 08, 2011 4:32 pm
1. GOOD FIT : Michelin PS2 R01 255/35/19 - Shoppinit
2. KNOBBLED: Michelin PS2 255/35/19 - Shoppinit
3. KNOBBLED: VRED Ultrasessenta 255/35/19 - SuicideAl
4. GOOD FIT : Vred Ultrac Sessanta 275/30/19 Daveperc (and others)
5. GOOD FIT : Vred Ultrac Sessanta 255/35/19 bam_bam and Bilko (knobbly bit removed just incase)
6. GOOD FIT : Good Year F1 Asymmetric 275/30/19 bam_bam
7. KNOBBLED: Michelin PS3 255/35/19 - Shoppinit
8. GOOD FIT : Vred Ultrac Sessanta 255/35/19 PhilRoach (h&r's)
9. GOOD FIT : Vred Ultrac Sessanta 255/35/19 Bilko (knobbly bit removed just incase)
10. GOOD FIT : Vred Ultrac warpdrive 275/30/19 gravity
11. GOOD FIT: ContiSportContact 3 255/35/19 backed off from 45 to 42PSI! - Digger, a good fit afaik, need replacing soon
12. GOOD FIT: Cooper Xeon 255-35 19. Monoi
OI! - You lot. Stick your last known psi figures in now the discussion has changed course. . .pretty please?
Post by bam_bam » Tue Feb 08, 2011 4:37 pm
5. GOOD FIT : Vred Ultrac Sessanta 255/35/19 bam_bam - 42psi
6. GOOD FIT : Vred Ultrac Sessanta 255/35/19 Bilko (knobbly bit removed just incase)
7. GOOD FIT : Good Year F1 Asymmetric 275/30/19 bam_bam - 38psi in summer 40psi in winter
8. KNOBBLED: Michelin PS3 255/35/19 - Shoppinit
9. GOOD FIT : Vred Ultrac Sessanta 255/35/19 PhilRoach (h&r's)
10. GOOD FIT : Vred Ultrac Sessanta 255/35/19 Bilko (knobbly bit removed just incase)
11. GOOD FIT : Vred Ultrac warpdrive 275/30/19 gravity
12. GOOD FIT: ContiSportContact 3 255/35/19 backed off from 45 to 42PSI! - Digger, a good fit afaik, need replacing soon
13. GOOD FIT: Cooper Xeon 255-35 19. Monoi
Post by Shoppinit » Tue Feb 08, 2011 4:38 pm
1. GOOD FIT : Michelin PS2 R01 255/35/19 - Shoppinit - 45 psi
Digger
Post by Digger » Tue Feb 08, 2011 5:04 pm
Another minor aside but I've carried one of these around for the last few years. Seems reliable and accurate.
http://www.amazon.co.uk/RACE-PROFESSION ... B000VZ8S26
Post by Shoppinit » Tue Feb 08, 2011 5:08 pm
The TPMS work very well I think. I have a slow puncture on my front left wheel and the TPMS alarm goes off as soon as it hits 37 psi.
The guages are good, too, but I know which is easier to use at 150mph :)
Digger
Post by Digger » Tue Feb 08, 2011 5:14 pm
When I change rubber I will save a few pennies and get the TPM sensors someone linked me to a few weeks ago. . .
http://www.alloywheelsdirect.net/option/tpm_sensors
Anyone bought these? Are they new?
Post by bam_bam » Tue Feb 08, 2011 6:03 pm
Digger wrote:When I change rubber I will save a few pennies and get the TPM sensors someone linked me to a few weeks ago. . .
I tried to but they couldn't get stock but they are the same manufacturer as OEM. If you have no luck, I bought the same ones from tyresensors.com (talk to Amy Hasson), but it still took 6 weeks to get in stock. I saved about £60 over the same Audi boxed kit.
I ran TPMSless for 2-3 months with a slow leak in one the rears, it used to do my head in even though I would repressurised before EVERY trip. Now I only check the pressures every 2-3 weeks, I usually check tyre wear at the same time.
Peace of mind motoring.
Post by HYFR » Tue Feb 08, 2011 6:12 pm
bam_bam wrote: Peace of mind motoring.
in an RS 6 !!
:drink:
Post by bam_bam » Tue Feb 08, 2011 6:26 pm
aka_dk wrote:
bam_bam wrote: One-less-thing-to-worry-about-motoring.
in an RS 6 !!
:drink:
FIXED.
monoi
Post by monoi » Tue Feb 08, 2011 9:55 pm
Shoppinit wrote:1. GOOD FIT : Michelin PS2 R01 255/35/19 - Shoppinit - 45 psi
2.5 bars
Post by Shoppinit » Tue Feb 08, 2011 10:07 pm
That's not much. Lower than the spec, IIRC.
Users browsing this forum: No registered users and 114 guests
